Are there any good performance shops in the northern beaches?
There is Joviant in brookvale and Envy Imports do some work.
I haven't done any modifications and haven't heard any gossip about the above two.
Do you own the silver R34 that frequents manly? I also see from time to time a yellow R34 on warringah Rd.
Mark
How about setting up a homework station somewhere on the northern beaches where you do assignments for free? =)
I've got a compiler I have to modify and get working by friday as well as a speech system to make room reservations over the phone (using a computer operator with voice recognition).
Anyone want to help?
Mark
Hey MRK25T,
Ya The silver one is mine:uh-huh: I think Ive seen your car around. I like how you put the R34 mags on. They look good on the car.
We really need a shop here in the northern Beaches!!!:burnout: I have to travel all the way to silverwater to have anything done.
Mark
I remember my Uni days .... well most of them anyway. I was mostly at the Uni bar !!
Good luck with the homework dood ! Wish I could help, but I've forgotten all that stuff - I only know about Crank Angle Sensors, TEIN Coil overs, Hybrid Turbos, Wastgates, Blow Off valves, etc (all the stuff they never taught at Unis - Damn)
Joviant are good guys and Brett (the guy who owns the joint) is a cluey character for Skylines. Hell all nissans actually.
As for his car, HOLY SHIT. its a bloody monster. Been for several rides in it a different stages of the rebuild and tune. Has over 450Kw at the wheels with a stupid torque figure.
Went for blast in his.....got back in my 255Kw GTR and it felt like a Golf or something...
Bribe, sell your wife, but get a ride in that car...
Its awesome!
He tuned my GTR and my old GTIR and I've seen and been in heaps of cars he's worked on. First rate work from what I've seen.
I take my car there for servicing.
Seb
Sebaz, you overtook me on griffin rd one night a few weeks after I was putting along the south curl curl beachfront. You turned left into Abbott rd at the round about.
I was the slow silver skyline holding you up - didn't notice you until you overtook.
Yeah I remember that.
no worries! yeah I'm around there a bit I guess.
Don't mind me I see a straight and I get blinkers..eh eh :P
Yeah I'm thinkin we'll have to have a Northern beaches catch up at some point.
Cheers,
Sebaz
Originally posted by FLIP
Hey guys,
Just wanted to say thanks for your replies and help.:)
i think i saw your car once when i had my '33 (white - plates NOZILR). i have a 180sx with the plates JCKASS now, i live in collaroy.
i take my car to hills in castle hill, i'd recommend it to anybody, worth the trek, thats for damn sure!
where is joviant?
Joviant is at a round about in Brookvale.
I think its in the same street as st vincents. Envy imports had their workshop nearly opposite vinnies but have apparently moved since I bought my car.
If your heading south on pittwater rd, turn left just before the bus station (vinnies is on one side of this corner and the bus station is on the other). After turning left go staight until you hit the round about - this is where Joviant is (from memory): on top of the round about.
Mark
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
