Odd Request: help a follow SAU'er out :)
Hi Guys,
I have a rather odd request, and I was hoping someone in Japan might find it in them to give me a hand :) But first, the story.
Once upon a time...... ...... I bought a Skyline R32 GT-R from Japan. As some of you may know, it recently arrived. Anyway, apart from being a Grade 4 car it also had (notice the tense) log books.
However, when I went to pickup the car there were no log books. I have spoken directly to the supplier who purchased the car at auction and he said that a) he doesn't have them and B) its not at all uncommon for this to happen as the onus is on the seller to send them on, and they often don't.
Anyway, as luck would have it there was a vanity plate in my car from a car dealer. Putting two and two together I assume this is the company the sold the car through the auction system. It turns out they are called "Total Automobile Excellent" or "TAX" -- http://www.tax.co.jp/
Anyway, I was wondering if one of the Japanese breatheren would take pity on me and perhaps contact TAX on my behalf and enquire if they still have the log books in there possesion?
Thanks guys.
Lucien.
PS. Before anyone jumps up and down and assumes this was some huge conspiracy to hide the true odo readings, the mechanic that complied the car said it was one of the straightest examples he had seen and in his opinion the kilometeres were genuine. My interest is really for provinence reasons more than doubting the odo reading.
https://www.sau.com.au/forums/topic/55428-odd-request-help-a-follow-sauer-out/
In all honesty Lucien I think we'd just get told that they dont have the log books full stop, end of story. These guys dont want to know about the car after sale, even less so after the thing has been exported...
Hey,
On one side you're lucky its only your log books. In my case in bringing in my soarer, i had the 12 Stacker 'Dissappear', the sun visor broken, some electronics hastily removed (bare wires, etc) and some other niggles with the transport company and wharfies.. on top of having my log books 'go'! So yeah.. just my 2 ¥en
Lucien, R32GTR manual, abridged version:
1. Pedal on right makey car go wheeee!
2. Pedal on middle makey car stoppy!
3. Pedal on left use to stop car go crunchy crunchy yuk!
4. Use stick in middle of seats and (3) changy gearu!
5. Big wheel in front driver to direct car holdy!
now get out there :D
I'll e-mail them Lucien, just give us as much info as possible about your donk, shassy, 2pak code, glove box diameter etc... :D
Just don't expect anything either positive OR forthcoming :)
I'll e-mail them Lucien, just give us as much info as possible about your donk, shassy, 2pak code, glove box diameter etc... :)
Thanks Rezz: your a champ (who now has PM) :D
LW.
Your service records, in all probability, would have been in the 'other' manual (ie: not the one that tells you what goes where and what to push). I can't see why they would remove that from the vehicle, before export - unless it's policy to clean out the glovebox
edit: spellink
  • 1 month later...
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
