Just a quick question - are slotted rotors worth having?
I have slotted rotors at the moment, but I am replacing my front brakes with R33 GTSt brakes
I can get new standard rotors for around $100ea, or slotted DBA 4000 for $260ea
Either way I will be using Racebrake RB74 pads, which I am told, Racebrakes don't reccomend using them with slotted rotors?
Cheers, Chris
https://www.sau.com.au/forums/topic/55430-slotted-rotors/
I always use slotted rotors, they clean up the pads, stop the little balls from rolling around under the pads and reducing the CoF. I have yet to find a set of drilled rotors that can handle the punishment though.:D
https://www.sau.com.au/forums/topic/55430-slotted-rotors/#findComment-1080869
Was it Race Brakes that told you about the RB74s...cause it goes against what they did to my brakes, bigger slotted rotors with RB74s...and they have never skipped a beat:)
About to give Comp 9s a run to see how they compare,
I am going from what a mate was told, as he got some pads off them, but from memory they said that they will work just as well with normal rotors, but I think I will go slotted anyhow, I will chase up a few prices on the DBA 4000's, if anyone knows of/or can get me them at a good price, please let me know :D
Chris
https://www.sau.com.au/forums/topic/55430-slotted-rotors/#findComment-1081487
i used either Winmax Sport pads or Endless NA-R pads depending on what tyres i was on, on std R32 GT-R discs with R32 GT-R calipers. Then I added Endless/ZEAL Straight6 slotted rotors to my brake setup. There was a marked improvement in pedal feel, stopping distance and also resistance to fade when i added the slotted brake discs, especially on trackdays. would definitely recommend slotted discs to an enthusiast.
https://www.sau.com.au/forums/topic/55430-slotted-rotors/#findComment-1081663
Although the RBA slotted rotors are a lot cheaper, with my full set of slotted fronts and plain rears coming in at $560. I use the RB74's and they are a good pad on the track with no fade yet with the backing shims removed and MOTUL DOT5.1 fluid. They are down to about 3mm now and are in need of replacement as they are getting very hard to control easily (not much pressure form slowing to locking).
https://www.sau.com.au/forums/topic/55430-slotted-rotors/#findComment-1082448
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
