Can anyone explain how the "on-demand" turbo boost works then?
Coz on our cars boost is driven by RPM.
no, not really, actually the wastegate controls boost on ths stock system.
And then of course many add an electronic boost controller that bleeds some of the boost the wastegate sees increasing boost again.
I would guess it is just some sort of electronic bleeder than increases the boost temporarily.
great feature for a race car tho, it really adds some strategy
Yeh it adds boost, but also changes the fuel and ignition maps so the car makes more power but suffers worse fuel economy:(
Yeh the Grp A days and turbos were great, but they never ran those sorts of boost levels for a race, two laps qualifying yes, but Pikes Peak Cars etc do it for the whole climb at high altitudes:) All impressive though:cheers:
I remember jim richards and the other guy who used to race the bluebird group A years ago getting interviewed on rpm on channel 10. They were talking about the tricks they used to use for qualifing like running stupid amounts of boost and using things like fire extinguishers on the intercooler when on boost to keep the intake air temps down, as there wasent such strict rules those days.
The turbos used to be scraped tho after running more than 2 bar boost boost rather quick even just for a few qualifying laps.
Zoom magazine No 55 has an article on the Bluebird and mentions
"in race trim around 1.6bar (23.5psi) of boost, which is pretty good considering it's 19 years old. As for the qualifying set-up, I'll let Fred Gibson explain:"We just wound up as far as it (the wastegate)would go. It would probably be a bit under 3bar (44psi) and would be pumping out over 400hp (298kW+). It was good for one lap, then the turbo was junk." "
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
