R31Nismoid Posted November 11, 2004 Share Posted November 11, 2004 by running that turbo i hope to have a decent power band with good overall power, you wont have good overall power with a 3037 on an RB20 Link to comment https://www.sau.com.au/forums/topic/55462-hks-3037-on-a-rb20/page/2/#findComment-1083626 Share on other sites More sharing options...
RBsileighty Posted November 11, 2004 Share Posted November 11, 2004 I wouldn't say it's so much a internal wastegate problem as it is an undersized spring in the actuator while running increased boost. Both of the stock 20 turbos I've been in contact with have been fine... but they are running .9 bar with no boost controller (no cat, 3" exh, and pod filter)... yet no spikes. If HKS sells their 2835 with an internal option... I'd imagine it's able to flow the amount of waste gas needed not to spike... They shouldn't be like FC S4 TII RX7's who have to port their internal gate in order to up the boost safely. Link to comment https://www.sau.com.au/forums/topic/55462-hks-3037-on-a-rb20/page/2/#findComment-1083633 Share on other sites More sharing options...
carl h Posted November 11, 2004 Author Share Posted November 11, 2004 hrmmm.... well i dunno then. like i said when i cranked the boost to 14psi i would get boost spikes, possibly due to the boost controler not being setup properly but i still think its due to the shoddy turbo elbow design. when my s13 was on the road i had the following setup : stock smic, 3" catback, punched cat, hks intake. i saw 10psi all the time with no spikes except on very cold nights, but even then it would only spike to 11psi. my stock tubo has a touch of shaft play, none round and round but some back and forth. as for the power bit, i suppose that since no one has really bolted one to an rb20 its all guess work for now. we'll have to see how she goes with it on there. Link to comment https://www.sau.com.au/forums/topic/55462-hks-3037-on-a-rb20/page/2/#findComment-1083650 Share on other sites More sharing options...
RBsileighty Posted November 11, 2004 Share Posted November 11, 2004 My old motor was running the stock dump like yours but cut part way down and welded to 3" pipe with no cat and with no spike... the only difference I can see is that mine (now in a buddy's car... has FMIC now but didn't spike with the SMIC either) has no cat at all and was boosting 12-13psi max boost with no boost controller. Anyway... here is an post from a while back with a RB20 and a 3040 setup: MRPrez's RB20 w/ 3040 turbo Link to comment https://www.sau.com.au/forums/topic/55462-hks-3037-on-a-rb20/page/2/#findComment-1083697 Share on other sites More sharing options...
Roy Posted November 11, 2004 Share Posted November 11, 2004 Careful, i think that was a hi-flow or custom something oratha that they called a 3040:confused: You would expect bit better power from one, or so i would have thought Link to comment https://www.sau.com.au/forums/topic/55462-hks-3037-on-a-rb20/page/2/#findComment-1083743 Share on other sites More sharing options...
RBsileighty Posted November 11, 2004 Share Posted November 11, 2004 He was only running 17psi if I recall with a small A/R at that... sounds like his tuner wasn't all that either. Link to comment https://www.sau.com.au/forums/topic/55462-hks-3037-on-a-rb20/page/2/#findComment-1083770 Share on other sites More sharing options...
carl h Posted November 12, 2004 Author Share Posted November 12, 2004 .82 ar isnt that small. 17psi is quite a bit of boost, just i dont think that he had the greatest setup. Link to comment https://www.sau.com.au/forums/topic/55462-hks-3037-on-a-rb20/page/2/#findComment-1084419 Share on other sites More sharing options...
RBsileighty Posted November 12, 2004 Share Posted November 12, 2004 Hello guys.. I just Got my Turbo package wcich is GT3040 with .63 exhaust housing, Tial 38mm wastegate and i also got an apointment with my mech. for the next thursday and he said after installation we power run it to see if i need to upgrade my Injectors and if so he will get me 600ccs (God help me with my fuel cunsumption ). so fingers crossed. He's running a .63 a/r... but going by these... that looks like the right size Guy here changed from 0.61 on HKS 3037 (bit smaller comp wheel only compared to 3040) to 0.87 and went from 256rwkW @ 1 Bar with full boost at 3500rpm to 280 at 1.2 bar but no boost until 5200rpm. Would be heaps slower on the road. HKS actully recommend the 0.87 for the 3037 kit they sell for RB25. Link to comment https://www.sau.com.au/forums/topic/55462-hks-3037-on-a-rb20/page/2/#findComment-1084638 Share on other sites More sharing options...
discopotato03 Posted November 12, 2004 Share Posted November 12, 2004 If you get the GT3071R take note of which turbine it has . There are different versions , the earlier ones used the GT30 84 trim turbine and the re baged 2835's use the 84 and 90 trim versions of the 56.6 major O/D turbine . These are a factory cropped GT30 turbine not known for stellar performance . They are generally found in GT28 style integrally gated turbine housings while the GT30's generally use Garrett or HKS non gated GT30 housings . Chow A . Link to comment https://www.sau.com.au/forums/topic/55462-hks-3037-on-a-rb20/page/2/#findComment-1084884 Share on other sites More sharing options...
