Hi, Guys. I thought I had worked all this out, but from looking at some dealers' websites and stuff, I am now confused. Some have suggested that all Series II R33 GTSTs are M-Spec. Which was news to me, but I thought "OK". I have now seen others suggesting that you could get R33 Series IIs and R33 Series II M-Specs. Previously, I had seen people suggest that there was only an M-Spec version of a Series I, and that all Series IIs got whatever goodies the M-Spec had (whatever they were).
My main interest in this is to determine what spec my own car is, which is a 1997 Series II. Can anyone help me with which is what?
I have tried to download the Nissan FAST software, but failed miserably.
I understand that the M-Spec has a limited slip diff as standard (supposedly). As I have just had to replace my right rear tyre (loads more wear than the left), I suspect that mine is not a limited slip diff.
Any thoughts/pointers would be welcome (and I have got nowhere with the search button on this one! And I have long since read the Series I vs Series II threads).
Cheers. :D
P.S. I think I have demonstrated my confusion by writing a really confused question! So, in summary: Is there a Series II M-Spec? If so, what distinguishes it?
https://www.sau.com.au/forums/topic/55493-r33-series-ii-m-spec-or-not/
yes there is an R33 GTS25t series II M-Spec.
and an R33 GTS25t series I M-Spec.
and no R33 GTS25t non M-spec.
There may have been a difference in R32s (try a search on that exciting question :D )
What you may find is that there was a mechanical LSD option on gtsts, some have the diff from the GTR VSpec. All other GTSTs have a viscous limited slip diff.
Re right rear tyre wearing faster....unless you have been doing lots of 1 wheel burnouts (commodore style) that is not the problem. What you need is a wheel alignment, most likely the toe or camber is out at the rear.
BTW if you want to post or pm me your VIN I can check it out for you
Duncan, thanks for the detailed reply. If you see two of these posts - it's because everything stopped when I hit the send button and I appear to have lost the first version!
Anyway, would you clarify one point for me: you said "No R33 GTS25T non M-Spec" - does this apply to both Series 1 & II, or just to Series II?
Thanks for the tip about the toe/camber. I will get that checked out. From my limited reading on the topic, I understand that the viscous coupling type LSD allows more slip than a mechanical LSD - hence the latter being fitted to V Spec vehicles.
I am pleased to say that I don't usually do Commodore style burnouts :) - or any burnouts for that matter. When I have booted it turning out of a side road, or wherever, I thought that I have had both wheels spinning at one time or another - maybe one at a time, but it certainly seemed like it has happened both sides. However, I haven't gone back to look at any black marks.
Meanwhile, my VIN is ECR33 130758. Thanks for offering to look it up.
If it helps at all, the Model No. is GGKBRTFR33VDA-A--A. The number beneath that, which I understand is for the transmission, is FS5R30A RC41.
Thanks again for your help.
Cheers. :D
Ahh well you already had the model number, that is the main thing, it can be decoded to tell which options were factory fitted to your car. FAST also recorded it as GGKBRTFR33VDA-A--A. There is a thread somewhere with some of the decoding, try a search.
Your car:
built in 02/97.
5speed manual
model: GTS25TM
And yes, all R33 GTS25t are M Spec, series I and II are the same.
There are 2 issues with viscous limited slip diffs....1 they have a low locking rating so 1 wheel can still spin in extreme conditions, and 2 they wear out, becoming an unlimited slip diff :D. Mechanical diffs like the v-spec diff use clutches and generally have a much higher level of lock up
Duncan,
You're a star! :nowigetit Thanks heaps for the info, mate and spending the time to look it all up. Very much appreciated. Now I can rest contented in the knowledge that I too have an M-Spec! :( The fact that everyone else does who has an R33 simply means they don't have something that I don't (terrible double negative, but hopefully you get my drift!)
I will chase up the decoding thread.
Thanks for that.
Cheers. :D
  Rezz said:
Bah... you're ALL wrong. It's "Type M". lol
Thanks, Rezz. I want to get this kind of stuff totally right - otherwise I shall simply become another who spreads shite under the guise of knowledge! :D
And I am sure that Duncan knew that - I simply led him astray by the expression that I used in my question!
So, if they are all "Type M", why bother making the distinction?
Cheers.
  LastTemptation said:
i thought the difference between type m and no type m was that the type M has a factory bodykit!! you all know wat im on about?
No even the cars without sideskirts were Type-M.
What about the Sedans? Were all GTS25t four door cars also type-M?
  krzysiu said:
I have a copy of CAR SENSOR straight from Japan here. For every series 2 it says:
R33 GTS25T M-SPEC 2
:werd:
It is possible that there was a difference in bodykits with R32 only. There have been about a million threads over the years on that one, I'm not sure what is correct
I still can't beleive I said a skyline was named after a hondah
Type R
Type S
Type M?????
R33 GTS25T M-SPEC 2
Please truust me on this one mate: It's R33 GTS25-t Type M.
What you saw in Car Sensor was R33 GTS25-t "Type M.... Spec 2"
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
