Hi all
Just picked up the car today and have a q..
The person i got the car said I should get the car tuned for 98 octane as it causes the timing to be a bit off and runs a little lean. Is the tune necessary and does this mean i need an aftermarket ECU? He suggested i use octane booster in the meantime?
Cheers
- Eric
edit: as you can see, i am a noob so plz no flaming ^^
https://www.sau.com.au/forums/topic/55527-r34-qs/
Skylines do prefer higher octane fuel, but a tune/aftermarket ECU isn't needed unless you are modifying it. About all you should do is reset the ECU, which causes it to relearn the timing advance parameters. Do a search on how to reset the ECU, there are several ways of doing it.
https://www.sau.com.au/forums/topic/55527-r34-qs/#findComment-1082400
I agree with Abo.. tho I would perfer to go with BP Ultimate, if possible.. :D Tho Ant is also correct you should reset the ECU to allow it to self learn/adjust it self to the different fuel qualities here. As to resetting the ECU I didnt find anything on the net to perform it, so I spend 100bucks n got the ECU data streamed (this is to see if the ECU already had any fault logged, at the time my HICAS light was coming on n off) and reset at the same time.
I found that resetting the ECU seems to make the car abit more responsive. Oh congrats on purchasing such a nice car. :D
https://www.sau.com.au/forums/topic/55527-r34-qs/#findComment-1085180
I've had my car running on BP Ultimate for 6 months now. The previous owner had used optimax and octane boost once a month. While I haven't reset the ECU, the cars running fine. It goes in for a regular service next month and as part of the service they will be dyno tuning it for road use...
https://www.sau.com.au/forums/topic/55527-r34-qs/#findComment-1085204
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
