i think it really depends how you drive the car...if you thrash it, i would say yes. it just lets the turbo cool down. but its not that neccessary to have one. you could always just sit in the car for like 30 seconds then switch off. its really up to the individual.
Provided you take it easy in the last 5 minutes of driving before you turn the car off, then a timer isn't really needed.
If it was, it would be installed by the factory.
Just don't thrash the car before you turn it off.
joel, you set the turbo timer for the length of time you want the engine to run on idle, so that the engine doesnt go straight from being hot-as to suddenly cool, which damages the internals cause of the sudden temp drop. i think you're thinking about boost controllers mate.
IMO turbo timer are overkill for street use. For everyday use, if you slow down and take it gently the last few minutes before arriving at your destination, you won't really need turbo timer that much.
Only when you take your car to the track regularly, it will be quite handy when you have to lock the car and walk away between lap sessions.
My understanding of the need for cool down is to prevent coking/carbonising of the oil in the turbo bearings, which can occur if you shutdown while everything is still hot. If you keep it running on idle for a short while (or driving low load as Sky031 suggested), then the turbo has a chance to cool down, lots of fresh oil is circulated through the bearings and the oil left sitting there when you shutdown won't carbonise. Carbonising of the oil will stuff your bearings.
All a turbo-timer does for you is automate the cool down, so you don't have to sit there. Personally, I drive low load and/or sit there for a minute or two or keep it running while I get my bag out of the boot and stuff.
As for locking and leaving at a track day - who the hell is going to pinch it?!! I left it running with bonnet up and doors open ....
Cheers.:)
Dunno where u normally go for track days, but I've seen certain tracks with open entrance to public (no security standing there) and anyone can just walk in and pinch anything from the pits when no one's looking... Some other tracks are good as they have one or two controlled entrance in/out of the pit area.
it is illegal in vic to have a turbo timer as it violates adr standards. your engine must not run when the keys are removed, this is an adr rule and a turbo timer bypasses this rule completely hence it being illegal. the purpose of it as stated is to let the engine run, while the engine is running the turbo is still spinning and has oil and water running through its water/oil lines. as soon as you kill power to the engine those lines stop flowing so the turbo halts and is most likely very hot.
with the use of the turbo timer it gets a chance to idle for a minute or two
most manauls for turbo cars suggest this and the r33 at least did have a factory turbo timer option its on the left of the sterring column down about 30cms, usually its a blank panel but on some r33s its a switch with short and long and the turbo symbol. i prefer the fact to leave it idle for a minute or two as it gives a chance for all the temps and shit (if high) to settle, at least a tiny bit
I recently read an editors reply from speed magizine from a similar question.
He said that they are a waste of money that are often incorrectly installed which leads to the fuel pump still pumping petrol out if you have a major accident. They exponse ignition wires that makes the time to steal your car dramatically less. He went on to say that anyone that doesn't take it easy 5 minutes before parking a their car doesn't deserve to have a turbo car.
Sorry, mate. I am living in my own little world and ignoring the realities of life in places less fortunate than Perth. If you ever get the chance to cross the Nullarbor, you would enjoy a track day at Wanneroo or Collie, I am sure.
Meanwhile, life way out West seems to have other benefits compared to good ol' Victoria, judging from comments in this and other threads about their application of the ADRs. The disparity between states for relatively straightforward rules seems farcical. If the ADRs said that all cars had to have a round steering wheel with two to four spokes covered in a non-slip grip, I reckon the state rules would be something like:
NSW: RTA would say cars had to have steering wheels and cops would defect you based on your age and who's in the car.
Vic: You could have either two or four spokes or three spokes with a leather grip, but not two or four spokes with leather grip, unless it was a factory option.
WA: You could fit an aftermarket steering wheel as long as it was not smaller than the factory wheel, but cops would still defect you if you were not white caucasian or if they were having a hard time with their missus.
QLD: You could fit an aftermarket steering wheel, as long as it was yellow suede to match the seats.
SA: Any steering wheels are fine, as long as they say "Holden" in the middle.
NT: Whatever looks cool when your fingers are gripping it really tight!
Cheers.
Mate got fined, at the servo, standing outside his car, leaning on it, with it running wiating for it to cool down... undercover cop car pulls up next to him, 'heres a fine for have the car running unatended'
of course it was a skyline ...
he was seriously leaning on the car while it was running waiting for it to cool down heh
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
