Snowmans 30th @ Spy Bar / QBH - 20/11
Howdy all.
I am turning 30. :bonk:
Those of you out there that know me know I don't mind a drink or two so I invite you all along to join me in celebrating this occasion. I will be starting the night at:
Spy Bar
173 Clarendon St
South Melbourne.
Saturday 20th Novemver
8pm - til late (they have a 24hr licence)
I have hired the Bushido function room there with its own music / Dj / bar facilities - and the public area upstairs will also have a DJ playing house and disco tunes.
Anyone who hasn't as yet joined the SAU crew for a drink feel free to come along as this is the perfect time to come have some fun.
:bananaman
At this stage I'm also thinking of heading in to QBH to see Ferry Corsten later in the evening.
:rave:
https://www.sau.com.au/forums/topic/55554-snowmans-30th-spy-bar-qbh-2011/
  • Replies 68
For people wanting to know about the Ferry Corsten gig - check out:
http://www.futureentertainment.com.au/flas...corsten2004.htm
Basically will be $50 on the door to get in. You will be able to buy tickets on the door. I'm not 100% going yet - but probably will. Apparently he doesnt start til 2am. But right now the music I have lined up for Spy will be hard to leave. Lots of late 90's anthems. But a packed QBH is so much fun. Saw PVD there..... a long time ago..... and it was awesome.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
