hey guys, i just installed a C's copy short shifter in my 33. installation was easy thanks to pranks DIY and it feels great, very solid and short. but its damn noisy as in i can actually hear the gearbox whine through the gears over the exhaust note. no noise prior to installation 2hrs before. just want to know if this is normal for a short shifter because of the way that its fixed onto the gearbox thru the base plate and clamps and that it transfers the noise of the gearbox thru the shifter itself. is this normal?? if not how can i reduce the noise?? my skyline sounds like my dads old crappy datsun:D:D
https://www.sau.com.au/forums/topic/55557-noisy-short-shifter-normal/
It made an awful lot of noise on my car when I put one in, it was really loud and horrid. Ended up taking it out and sell it within a week. That was C's.
Not sure about Nismo short shifter, has anyone tried it? Perhaps Nismo one might be quieter?
probably due to the fact that the new shifter is a solid core, where as the original r33 one has a rubber-filled core to reduce stiffness and noise transfer... this is normal
that makes alot of sense, i can even hear the starter motor turning over chrisply thru the shifter itself..its bizzare. glad to hear that this sound is normal though it is slowly driving me nuts:D:D
I'm not sure about the Skyline Nismo shifter, but I know that the Nismo S13 Silvia/180sx shifter is no where near as short as the C's S13 shifter. The extra noise is the same with the S13 C's shifter so I've been told.
i have no idea what is making the noise, the top clamp is very tight... now that u mention it i might see if there is a gap between the spacer and the top plate / clamp..?
does the fact that it is solid have anything to do with it?
does it matter if the 'wave' washer is under the spacer rather than over it? its difficult to fix as i have no idea what is actually the casue..
    • Looking for a S2 front grill for an R34 GT/GTT Doesn’t have to be in excellent condition as I’m looking to paint it. Would preferred if the clips were around.    The $500 this marketplace guy is asking sounds ridiculous in my opinion.
    • Nah, just take the other one off too
    • A mini mini-gun.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
