hey guys, i just installed a C's copy short shifter in my 33. installation was easy thanks to pranks DIY and it feels great, very solid and short. but its damn noisy as in i can actually hear the gearbox whine through the gears over the exhaust note. no noise prior to installation 2hrs before. just want to know if this is normal for a short shifter because of the way that its fixed onto the gearbox thru the base plate and clamps and that it transfers the noise of the gearbox thru the shifter itself. is this normal?? if not how can i reduce the noise?? my skyline sounds like my dads old crappy datsun:D:D
https://www.sau.com.au/forums/topic/55557-noisy-short-shifter-normal/
It made an awful lot of noise on my car when I put one in, it was really loud and horrid. Ended up taking it out and sell it within a week. That was C's.
Not sure about Nismo short shifter, has anyone tried it? Perhaps Nismo one might be quieter?
probably due to the fact that the new shifter is a solid core, where as the original r33 one has a rubber-filled core to reduce stiffness and noise transfer... this is normal
that makes alot of sense, i can even hear the starter motor turning over chrisply thru the shifter itself..its bizzare. glad to hear that this sound is normal though it is slowly driving me nuts:D:D
I'm not sure about the Skyline Nismo shifter, but I know that the Nismo S13 Silvia/180sx shifter is no where near as short as the C's S13 shifter. The extra noise is the same with the S13 C's shifter so I've been told.
i have no idea what is making the noise, the top clamp is very tight... now that u mention it i might see if there is a gap between the spacer and the top plate / clamp..?
does the fact that it is solid have anything to do with it?
does it matter if the 'wave' washer is under the spacer rather than over it? its difficult to fix as i have no idea what is actually the casue..
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
