If that is USD it is quite pricey for a Tomei HICAS lock kit. They are around in Aus for about 150-180 AUD.
That's the way I was going to go too.
  • Replies 580
The Galant VR4 that I bought in SEPT last year finally his Aus soil on Saturday. 5 Frikkin Months and then there will be all the crap of compliance etc.
By the way. Anyone recommend a compliance workshop for 15yo in Brisbane?
Argh sorry man.... Your car won't be here till sunday 1130 pm or even monday morning. Sorry to keep you waiting. But i,ll let you know if it does a good victory donut on the wharf when it gets here. Might even post a pic for you.
bloody wharfies...
Damn clowns at seaway are screwing me around. 2 days in a row they said the car would be delivered to my house and both days nothing. Really ruins my weekend as I work over 10hrs + a day during week days and can't play around with it IF it arrives Monday.
I don't even know where this car is. Truck driver went to pick it up yesterday (for the second time) at lunch time, I get home from work and mum says no car here sonny!!!!! Can't get in touch with anyone there at seaway too. Sooooooooo angry at them right now, they've just left me hangin. :usuck: :P
Edit: 4 days later it has arrived :P
richard, I can give you a circuit diagram to make an electronic decice that taps into your HICAS computer and negates all the signals comin out of it if you want. No need for bar, just make the system blind.
well guys, another update.
Went right through cleaning the interior, took the kick panel off and what do I find? (No not the power fc I was hoping for) but a MINES Tuned ROM!
explains why it seemed like it was running rich!
mark
that sounds promising. I'm not exactly a precision soldering machine though, which may be a problem :cheers:
Blacky is yours the Ivory Arrow frim KLine?
It says the origin is from Singapore - is that where these car carriers start from?
How long does it actually take for these ships to go from Japan to Freo?
The ivory arrow is in. went down yesterday and had a look at all the cars. Quite alot of 32s and 33s on the docks. Singapore was the last stop for the ivory arrow before it got to fremantle. i believe the 28th of january was when it left it's first japanese port. Hope that helps.
well my car has arrived and has apparently cleared customs. The problem is that it failed the quarantine inspection. I was supposed to get it last Friday now Monday but i've just been told it will be on a truck to my place 'morrow.
(finger crossed) Hopefully that Recaro seat chucked in the back is still there.
this waiting is killling me...
everything is done on the car, but now i'm just waiting on the plate from the engineer. it sucks when such little things are holding it up. i've been waiting so long i'm itching to get it on the road.
well it's a bit of a bummer, but the plate didn't arrive today, so no blue slip. :)
oh well, the good news is that it will be there in the morning so tomorrow I must registrate. then I can drive to shinjuku macdonalds and get that terriyaki burger I've been waiting so long for.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
