This topic must have been argue countless of times. The response anyone get will depend on the site he is in.If in silvia wa ..they will say 180 rocks! but then in here skyline rulz.
Seriously if anyone here although owning a skyline can be on a fair basis and judge the two car fairly?
pros and cons?
resale?popularity?
maintainence?
Hope will recieve response on the fairest basis!!!!!!!!!!!!!!!!!!!
cheers!
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/
I guess it depends on what you're after. If you compare an SR20DET 5spd 180 to an RB25DET 5spd R33, then the 180 will have the price advantage and the practicality of a hatchback. But I'd think that the Skyline would be better in every other department, faster, better suspension setup, better brakes. Probably similar value for money so i guess it depends on how far you can stretch the budget and what your needs are.
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083223
IMO the Skyline is a far better all-rounder, but has a weight disadvantage if track work is your thing. As much as R32 guys like to go on about how light their cars are (or how heavy R33s are) afaik there's around 50kg between. Skylines definitely make more power stock, and (I think) a stock R33t will beat a stock SR20DET'd 180SX, but how many stockers do you see? Light mods, the SR powered 180 will win, particularly in corners. Medium to heavy mods, the Skyline will show the SR a clean pair of heels, although the extra weight will still haunt them a little in corners. Reading that back it sounds like the Skyline is a barge that doesn't turn... we're talking degrees here. Both cars handle absolutely brilliantly, and the Skyline wouldn't be far behind the 180SX, nevertheless the 180SX would be in front. Well the ones I've driven would be, anyway. I'm only going on the half a dozen or so of each that I've driven, so I'm not exactly drawing on massive experience here. I'm trying to be objective though ;)
180SX
Pros
Cheap
Parts are easy to source
Popular
Maintenance is fine, everyone knows them now
Resale - not really sure as I'm not buying or selling atm, but they're already cheap
Relatively light, good motors
Well balanced chassis
Turbo models had strong drivelines, good brakes
Look good
Heaps of hot up bits available
Easy to get going very well on light mods
Cons
Cheap
Popular = every prick has one
Some parts are still exxy
Getting long in the tooth, most have been flogged
Ultimately won't keep up with heavily modded Skylines
CA18 is relatively peaky
Skyline
Pros
Getting cheaper. Some R32s are nearing 180SX/Silvia territory
Popular
Still relatively light, good motors
Look good
Better quality interior than 180SX
Non GTR's also had optional 4WD (albeit only in non-turbo form in R33, unsure about R34)
If luggage space is your thing, get a Stagea (Skyline wagon)
Cons
Popular = every prick has one. At least there are a few different model types
R32s and S1 R33s getting long in the tooth, many (though not all) earlier models have been flogged
Stuff all boot space in R33
RB20 in R32 has bugger all torque off boost
If you're not familiar with them, spec differences can be confusing
That's all I can be arsed typing at this time of night :)
If you're thinking of buying, neither will disappoint!
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083368
Great response Marc!
I have owned both a skyline and a 180sx - and I have found the skyline alot more comfortable and nicer to drive. I had a 1993 180sx, so it had those crappy hessian bag type seats and trim. But if you get post 1994, I think the 180sx comes with velour seats and trim, like the skylines have. The 180sx is also quite simple inside, as you've probably seen, compared to the skyline.... But these are all asthetic qualities!!!
Like Marc said - the 180sx is alot cheaper to maintain. I have found the skyline to be quite expensive after owning a 180sx. S13's have an abundance of parts at wreckers and stuff and they are cheaper on fuel (but this is relative to what mods you do :) ). But this doens't matter if your not concerned about maintence costs!!
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083589
I currently own a CA18DET 180sx with just light mods (Turbo back exhuast, pod filter, boost up, etc) and my friends R33 with same sort of mods plus FMIC has about a three car lead on the 180sx over the quarter mile. :)
In terms of comfort and interior my old R33 wins hands down.
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083641
Agree - it's been said far many many moons, that the best mod you can do to your car is to 'upgrade' the driver.
But yeah, just test drive until you make a decision. When I was in the market, I ended up being torn between an S14a 200SX, the R33 I have now, and a TT Soarer. Three very different cars, and in the end the Skyline won it for me because it's more focussed than the Soarer, and more comfortable and smoother than the 200SX, and I planned to do a LOT of kays.
Edit: my god I'm a post whore when I'm stuck at home (flu). Sorry ;)
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083979
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
