Vic section - lack of action recently...?
  • Replies 90
you sir, are just jealous that you moved to sunny queensland and bikini season is almost upon us... man... i am so in the wrong state...
haha.. I have to wonder what you guys do for the other 6months of the year when theres no bikinis.. (esp in Melbourne).
*scrolls up* Oh wait, I see now.. you have your SAU friends.. and spanking.. and such things :D
last time I spanked my gf in the heat of the moment i got no sex for a week :D she's not into that sorta shit as it turned out.
aaahahahahaaha :D I love it! nothing like slapping her arse in the heat of the moment doggy stylz, adds to the fun :D
I see that in my absence you've all lost the plot again.
Those who posted at the start of this thread were of course dead right.
The reason for the lack of action in the Vic section recently IS because I wasn't around.
Hope all are well, those I know of course. Those I don't, I'll hold back my well wishes until I do know you.
Now as "Gobler" said in Raiders of the Lost Ark:
"...what shall we talk about?"
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
