Almost jsut after i purchased my car i learnt about the wet road + rear wheel drive + boost issue.
I've been super gentle with the velocitator (read: go pedal) since then.
Velocitator!LMAO!!!!I just GOTTA remember that one!
I learnt that rain lesson too, i think that most people have to go through something happening to them/close mates/their car. Well, in the same one i learnt never to let your mates drive your car.... so sad -_- but seriously, people are going to do dumb things and have fun in the wet, its just too hard to not do it. Probably the only thing you can be thankful for is that some of them wont do anything stupid with mates in the car (me included). Try not to rev up your mates and FFS, teach people to drive responcibly with others in the car, its not just your life its theirs too.
  • 3 weeks later...
wanna have the last laugh?? Heres a how to guide.....
1/ Go and buy yourself a HSV or Holden Or Commonwhore shticker.
2/ Place it at the bottom of your shitter.
3/ Drop your pants.
4/ Snap one off.
5/ take a glance at your work
6/ smile at the sight of the smudgey, corn riddled, distorted image that once was......holden.
(dont forget to avoid splashback!!) :dump:
Why is it that all most all Commonwhore drivers wish to try and race me when I am cruising around in my R33, but most other drivers even in much more powerfull cars then Commondoors dont bother. Most Ford drivers dont try either. They must have wierd minds like volvo drivers.
My funniest experience is a bloke in a VN SS 5speed who multiple times would drop it back to second at 60km/h and roar off, then slowing down to do it again.
He had a car full of mates.
The last time he did it the motor began ticking really really loudly then started to miss badly until they were forced to pull over. lol. :)
I drove past grinning, the almost about to cry expression on his face I will never forget and still to this day makes me smirk. :D
No - they just have small penises and they feel inferior so they must try and prove them selves - problem is they usually fail. :kick:
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
