  • Replies 52
dude, he is making the money on the postage .... the postage doesn't really cost US$30 per piece - I am sure it is significantly less - he is avoiding Ebay charges (as they charge a percentage of the purchase price as commission).
The signs are fairly large, so even tho they are light they go by cubic weight!!
Is it sent air freight?
don't know, I don't really give a crap, as long as they're here within 3 weeks and they arrive safe and sound!
fyi buyers - I paid shipping insurance on them too, for peace of mind.
Order is in, I have paid for them all, and am waiting for him to notify me the shipping EMS numbers for tracking. Will post them up when available.
also fyi, he said you can change the light bulbs in the head unit and change the colour of the signs. I am not sure what type of bulbs these are, but hopefully he will let me know or send some spares.
Andrew
the payments have now all cleared and the guy is making the signs as we speak. We (I) got absolutely ripped on the Paypal A$ to $US conversion - they converted at US76.5c to the A$ (should have been around 80c to the A$). So it turns out everyone's orders are $5 more expensive. But I not gonna lose too much sleep over it. If you wanna give me the extra $5 each when you next see me at a cruise then that would be nice ..... if not, it's not the end of the world.
Will let you all know shipping/tracking numbers when available.
My signs arrived today! They look pretty good, but one doesn't work. Hopefully it is just something simple, but haven't had a chance to look yet. Instead of cutting and joining wires, I just got a travel adaptor from the hardware. Works like a dream (on the sign that works anyway)
Thanks for all the time you put into this Andrew. Your a champ. Finally my lounge room looks like a cheesy pub! :)
P.S. I'll give you the extra money owing when I see you. Thanks again, Ant. :)
Hey guys
my signs arrived on tuesday but ive been away at my gfs so i didnt know until i got home today
they looks sweet :P
just need to go get sum adapters now
btw andrew how much do i owe u?
got mine today too - and the email from the supplier giving shipping/tracking numbers :P
Mine are sweet as, I got 6 in total and they all work and are cool. One had the bulb dislodged (maybe like yours Ant), so I opened her up, pulled out the light assembly and put the globe back in. Works perfect now! Fyi, you can buy the bulbs around the place apparently, so if you prefer a different colour it is an easy fix.
Don't worry about the cash Kamikazee - it is too hard for the sake of $5. I just made the comment cos I am likely to catch up with the other fellas sooner or later. I just forgot Paypal give such a shitty exchange rate!
And don't bother with buying an adapter - just cut the end off and rewire a new plug on the end - 2 minute job and much cheaper. You can buy plugs from Woolies, Coles etc.
Hope you all enjoy your signs!!
got mine today too - and the email from the supplier giving shipping/tracking numbers :)
Can you post up a picture of what they look like lit up next to something, so we can see the actual size of em?
I went into a new bar world shop last night looking for something similiar but all they had were shitty little globe type lights which said crap like bar open, and they were selling for $50.
Luckly these are coming from America otherwise if they were sent from anywhere in Asia customs would have checked em all out.
these are actually sent from china - or so it says on mine
den these are about 30cm long and bout 15cm tall (plus the metal bit at the top)
I will look for these when i am in hong kong in 2 weeks time.
Hopefully i can post some back to myself in Aus while there.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
