Originally posted by EVL R33
Dave,
That is a factory paintjob, they came out both two tone and full colour..   The factory paint code is BN6 which is 'Deep Marine Blue with Pearl".   In fading light and under street lights at night it has a purple colour to it.
And it was a series 2 R33 colour only.
Oh, and welcome to the blues club EVLR33
https://www.sau.com.au/forums/topic/5561-colour/page/2/#findComment-87904
Dave,
Brett
Edit.   InitalD from perth has the two tone one with the green pearl.  Don't think his is the same code as mine.
The code for the two tone job is 1N3, which broke down into BN0 for the aqua blue and... er... something else for the grey. I just had to get a new grill painted, so I had great fun with finding out what colour matched up with what code.
here's the end grill result. :)
https://www.sau.com.au/forums/topic/5561-colour/page/2/#findComment-92809
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
