some great discussion going on here guys!
anyone got any more comments?
i'm thinking of taking my coil packs out this week to give them a coat of aryldite + electrical tape (read the thread in the maintenance section about it) and if its still missing then changing the plugs again. I don't think its a gap issue as it happens at idle and not above 4000rpm like most missfires...
haven't heard anything from Sydneykid yet... were are you, gary?
Its normal for RB20DET's to pop a little on idle.
Mine pops a little and still does with the RB30DET.
On the dyno the AFR's on idle are a perfect 14.7:1.
You can richen up the mixture slightly, this solves the slight pop on idle.
im saying that a auto at 12psi and 136kw is farken great im also sayinying that u can put 15psi in a fact turbo and it will have no prob, predator obviously u have had trouble in your time or bad luck ,going by your threads.post your dyno sheet!! boy
I was pulling around 180rwkw with 10psi on my (sold) r33.. any further than that did not show any gains in power. At times over the near 2 years I had it, I had it tuned (only via SAFC unfortunately) for 10psi, 11psi, 12psi, and 14psi I think at one point - none of which showed any noticeable increase in power other than bragging rights "FullSiK im jUz runnin 16pound b00st maan aNd itz kRaZy!".
I found 10-12psi was more responsive and better to drive, winding it past that was just a pointless exercise.
I know this sounds a little dodge, but I remembered I gave all the old dyno charts to the new owner .. there a few on the forums about the place though: http://www.skylinesaustralia.com/forums/sh...363&postcount=8
if only the old attachments worked :spank:
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
