What are the controls on a R34 steering wheel for?
My uncle just picked it up and we're trying to work out what they're used for? Its a tiptronic gearbox. Is it for gear changing? Radio controls? Cruise control?
its for gear changes, if u look down towards the top/right of ur gear lever, there should be a button to turn it on.
Ah ok, was wondering what that switch did :)
So its got the controls on the right land left side of the steering wheel, Im assuming you can use either to change gears up or down?
And to be able to change using the steering wheel controls, does it have to be in tiptronic mode as well, ie not in [D]rag mode?
oooh.. sorry to hijack but whilst on the same subject.
is it bad to keep changing to manual mode whilst driving? i have a really bad habit of changing to manual mode and then downshifting when approaching a red light.
also, weird thing happened to day.. was in manual mode and stopped at a roundabout.. the tcs, slip and hicas light went on and i "stalled" wtg? how does this happen? who stalls on an auto? my car is stock btw.. weird, but there a first to everything i guess
i would of thought that if an auto car has a tiptronic option then you should be able to change driving styles as you wish.
but i would think that it would be causing extra strain on the gearbox when you keep on changing styles. Maybe best thing to do is choose to stay in Drive or just keep it in tipronic mode and not change constantly...maybe ask a nissan dealer some time and see thier opinon
That depends entirely on the logic that controls the triptronic function. If it holds gears so you can bounce off the rev limiter, only down shifts if your about to stall, matches revs and blips the throttle, and changes quickly, then yes they can pretty much be driven how you want.
However, most don't do all (or any) of those things and seeing as the R34 GT-T implementation is old (by tiptronic standards) I doubt its terribly advanced.
LW.
ecl: From experience changing from triptronic (manual mode) to full auto on up shift is bad! :D the engine/gearbox dont sound too happy.. on shift down seems to be fine. Going from full auto to triptronic (manual mode) dont seem to have any problem at all at least to me anyway.
2c worth. :D
2c worth. :D
thanks everyone
Thats a switch for a valve in the exhaust. Factory option.
Either allows more flow and louder or less flow and quieter.
Unfortunately the valve tends to get stuck due to the gunk in exhaust gases combined with temperature and water.
no offence to yourself or your uncle tez, cos you've chosen very wisely ;) but did you guys looking into buying a R34 at all or did you just go and get one, one day? please don't read a condescending tone into that, cos there is absolutely none, but i'm just curious that you'd go out and buy a R34 and not know what the buttons on the steering wheel are for?
Did the yard/private owner not tell you about the car? Did you take it for a spin?
Anyways, happy driving. And if you could fill us in on the car, that would be great! ;) Ie, colour, 2/4 door, any mods?? :rolleyes:
cheers.
Thanks for everyones help.
He did take the car for a test drive and that stuff, but probably not as thorougly as one should have ie test everything. Although he had been looking for a R34 for a long time, in tiptronic, and in good condition, and this one was.
Its got about 35,000km with book (??) and is in immaculate condition. No modes for it, and I dont think there are mods planned as yet. No pics yet, although the car looks *exactly* the same as yours in the sig, although with different wheels. Even down to the rear coathanger
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
