Fair enough I can get some boost into it but I wouldn't mind knowing the finer points.
The EVC has low high and manual, the way i work it low is not settable or is high but manual is on the min max dial.
I also have a scramble trigger which apon pressing a trigger gives a bit more.
I don't under stand why you'd have Low, high, a bit higher, and a trigger overboost???
any ideas?
https://www.sau.com.au/forums/topic/55661-how-to-use-hks-evc/
God dam that's an old unit, hope you checked the solenoids are still working OK.
Volume is for setting the ratio, but I have never used that HKS EBC model, I'm unsure how you can set the low and high boost, perhaps low is factory?!? sorry I can't much help. I can probably check with someone here, if I find out I'll let you know.
there was a site that had printable manuals for HKS EVC's. Can't remember the address or name, something like autospeed or autopower. It was a european site, the usa/au sites don't have the manuals.
you'll have to do a search.
