Personally, I am going with the SAFC 11 current version, for ~$400 this gives a good A/F ratio result. You can't play with ignition as the auto needs ignition retard to give smooth shifts and not overload the transmission with torque while changing gear (prolongs gearbox life). So looking at other options with ignition control capablity (EManage for example) is a waste of money.
Full ecu upgrades, Power FC for example, aren't on the cards for me as they have no programming for the auto. Sure they run the engine itself just fine, but not the auto for the reasons above.
I am looking at around 200 awkw (that's about double the standard kw) and I have seen plenty of SAFC's work perfectly well at that power level on other RB25DET's. So the decision is pretty easy for me.
Hope that helps:cheers:
http://www.bikirom.com/
do a plug in board to allow remaping a r34 rb25 neo
anyone know if its the same ecu in the neo equiped stagea's ?
what about the hardcore aftermarket ecu's like motec and autronic ? I have seen autronics control auto sr20s before .
Nope, they have no shift logic. What you can do is use one of their outputs to change gear. Stuff like at 60 kph change into second, at 120 kph change into third etc. This is OK for a drag car, but not realy "shift logic". Where you want smooth up and down changes, down hill, up hill, under load, cruising etc etc
I was told that the lines of code to get an auto to changes gears properly, all the time, was over 1,000 times more than that used to get the engine to run. That's why you can buy manual car ECU's easily, but very very few auto ECU's. In fact the only one I have seen is the Power FC for Toyota Chasers and my understanding is it has Toyota auto shift programming anyway.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
