I have an R32 GTST and my turbo is kicking the proverbial bucket.
It used to just make this shreiking noise when it reached high boost (factory settings mind you). But now I can here it flapping against the casing all the time... I am worried that it is going to shatter and run through my block.
Does anyone know how I can avoid this i.e is there a way to remove the turbo until I can replace it and still drive the car in the mean time?
OR
Does anyone have a factory turbo lying around that they don't need? i feel I am in quite a hole with this one :Paranoid:
Any solutions would be great.
Thanks,
BlkR32
https://www.sau.com.au/forums/topic/55679-urgent-turbo-help-please/
Im no expert but why cant you disconnect the air flow meter and put it onto the plenum chamber pipe and then disconnect the wastegate and hold it open somehow (tie wire or cable tie if it dont melt) and disconnect your intercooler pipes so if the turbo does blow shit everywhere just direct it to the bottom of the engine bay or something...
Would that work ?
Probly not but worth looking into maybe :)
I lost my factory turbo (R33 though) while driving. Large pop and it went. The guts of it ended up stuck in my cat convertor(no other damage to the engine). I drove around for a week with no turbo while I was waiting for a replacement. The car will still drive but the compression is wrong for NA and it will strain your engine so dont do that for very long plus the power output is similar to that of a lawnmower!! You can 'turn' off your turbo by disconnecting your vaccume line. If your not sure a mechanic can do this in about 2 minutes. My suggestion is that you do not drive it too far without it. If you need a replacement turbo cheap let me know as I have a friend (in Melbourne) that sells used parts cheap for imports. If your budget is tight try and get a R33 turbo at around $400 second hand. You might find a R32 turbo for slightly less but you may as well get a more efficient turbo for an extra $100.
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
