Has anybody found a place in the ACT that actually knows how to properly wheel align a Skyline?
I made the mistake of taking mine to BoB F**king Jane F**king Tmart (yes, yes I know, but I had to get it done in a hurray before driving to Sydney, and they were the only ones that didn't seem to have any customers :boohoo: )
Anyways, the car pulls to the left now and they didn't even bother to centre the godamn steering wheel. Don't think I could be bothered going back there, cos even if they did try to fix it, they clearly have no idea what they're doing (I should have realised when they didn't offer me a printout with the alignment specs).
Would be great if someone knows a decent place that's open Saturdays too.
BTW - how many of you still have your HICAS running?
https://www.sau.com.au/forums/topic/55689-wheel-alignment/
Yeah i took my stagea to pedders and it pulls to the left. i took it back, and they said they didn't know what was wrong, because acdcording to how they'd set it up, it should pull slightly right (to counter road camber) anywho, then they said it might be the tyres because they're a shit brand and have been driven on underinflated for a while from the damage they have (by previous owner) so they gave me a free wheel alighnment when i get new tyres
https://www.sau.com.au/forums/topic/55689-wheel-alignment/#findComment-1086490
Hey, I had the same problem from the same blokes. Tyrepower did mine fine!
https://www.sau.com.au/forums/topic/55689-wheel-alignment/#findComment-1088365
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
