Simple questions guys coz i dont know. Thanks for Help... :)
Are rb26 coil packs much better than rb25det(series1) coil packs?
Can you put rb26 coil packs on a rb25det(series1)?
What coil packs should i get for my rb25det(series1) because they are my week point now, its breaking down now that i can run more boost with my hi-flow turbs..
thanks again,
Fane
https://www.sau.com.au/forums/topic/55694-coil-packs-question/
there is nothing wrong with the std coils when they are working, the cheap option is to fix your ones. If its breaking down at higher boost but fine at lower boost, chances are the pack(s) just have a tiny crack in the housing. You can fix this for nothing with some electrical tape.
Splitfires are great, but for a hi-flow application are not a neccessity, and i wouldnt spend 600-900$ on a set if i didnt have to!
cheers for the responses guys...
sly33: its slightly breaking down but its not like when the plugs start missing whenm you havent gapped them close enough....its very soft....could it just be the AFM maxing out?
i have hi-flow turbo @ 12psi, fmic and all the usual bolts ons and a turbo back...stock afm and fuel system... what you reckon?
if everyone still thinks its coils...then where do i put the electrical tape?
fane, it could possibly be your AFM, although if it happens at just 12psi its a bit more unlikely.. obviously you dont have an FC or you could easily check if it was the afm.
id still give the coils an inspection, its not real hard, if you can change plugs you can do it.
So you need to find a crack before you go taping them up!
i dont have the pictures of my coils anymore... if i can remember, at the front (or back, depending on which coil) above where the rubber boot ends there are some raised numbers, its around here that you may find a tiny vertical hairline crack, mine was so small i had to put it under very good light to see it, and even then i wasnt sure if it was actually cracked, but i ran a couple layers of tape around the coilpack body, covering the crack, and straight away it ran perfectly. The one that went was the one closest to the firewall, and the one i checked last! so you may want to start from the back one! I have heard of people finding cracks in nearly all there coils, so have a careful look with a magnifying glass.
fane mate they are all the same to answer you original question, only the rubber stem varies in length between the rb20 25 and 26 and this can be swapped over by simply pulling it off and interswapping to your needs!!!
thanks s13drifter
sly33, i took car for a drive and it starts at 12 an goes all the way up to 16
basically what my car is like is that its just a huge flat spot....HUGE, then about 6400rpm really kicks you in the ass til 7200rpm....
but i just want to know what it could be.... on my SAFC it used to just hit close to 97 and 98% on the airflow, now it hits 100% real early when the flat spot starts, thats what makes me think its the afm.....whats everyone reackon..... ps. AFRs are around 11.8-12
steve, i asked whether they would fit, because i have a 25 and i want to put them in....so in other words it would deffinately fit...
