i have for sale a complete RB20DET from rocker to sump. blows a little bit of smoke runs really well and idles properly. includes turbo, afm, etc. from a 1/2 cut and may have other parts needed. eg. for auto to manual conversion.
still in car and starts and drives perfectly - serious buyers welcome to test.
$654 ono
in melbourne - doncaster and coburg
any questions let me know
thanks for your time
shaun
https://www.sau.com.au/forums/topic/55745-complete-rb20det-654/
