GTS4 & GTR similar?
Well I did the GTR conversion on my GTS4 2 door and the rear cradle is the same, so i just changed the Diff and left the cradle the GTS4 one, the rear brakes are the same as the GTR ones, so just change the front ones ( rotors and calipers) as the hubs are the same too, suspension is the same but it will be slightly differant rate on the GTR and you'll need to cut some more holes and enlarge some to allow for the intercooler piping, apart from that the rest is just bolt up stuff, unless your doing the auto to manual aswell, the fire wall has no recess for the boosted clutch that the GTR has, so i used a r31 clutch master, and you'll need to cut out the centre console for the shifter as the GTS4 auto shifters are cable.
Thanks heap's for the imput.Dose any one else know if the RB26 loom will plug into the gts4 loom down near the ecu?plugs look similar,have a power fc for GTR want to use it in conversion as well. Also what about ATTESA contols main comp (under parcel shelf) and Gsensor(under console)?
 Share
