I've got a Field Boxer " series SFC-Hyper R controller for sale.
This unit will measuer and record
0-100m time
0-200m time
0-400m time
0-100km/h time
top speed
RMPs, current and peak
mixture (rich or lean)
it allows you to adjust your fuel mixture up and down up to 30% at 1% intervals at every 1000 rpm up to 8000 rpm. 3 different maps are available.
Lastly it is a speed cut defender so that the fuel cut won't kick in a 180km.
For more details see: http://www.field-net.co.jp/english/lineup/...hyper-r/op.html
Currently set for an RB26, but suitable for just about any Japanese car. I've got the manual in japanese, which I am trying to translate so that it can be used on other cars.
Currently selling for $335 new, http://www.inlinefour.com/fielsfchypfu.html and other places on the web.
Asking $200.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
