can you tell me what you had to take off this shifter to make the quick shifter work??
i bought a standard shifter off someone on here and when i rcvd it he had raped it for all the parts required to make it work.....
if it still has the nylon bit above the metal ball in the centre of the shifter let me know.... this is the bit that locks the shifter into the box...... also like to know if you will COD it to me in Sydney at my expense...... if your not quite sure of the bit i am talking about send me a PM and i will send you links to some pictures.....
You just pull the stock shifter and 2 circlips out and replace it with the parts of the short sifter, which is basically a spacer you add to the bottom and then insert the new short shifter stick and bolt it down.
You can see from the picture that it has both nylon parts to make it work. The 2 circlips which i will also send you is the thing that locks the shifter into place so the one i am selling will work perfect.
Send me a PM and we can work out payment.
  • 4 weeks later...
