Help with steering!!!
Hi,
I have just done wheel balance on my car on all 4 tyres.
This has been done twice now at two different TyrePower shops.
Resolution after $120 spent: The steering still shakes as soon as I hit 100km/h.
I thought it was my tyres, I don’t know. I don’t remember hitting anything at all.
So I don’t think it would be my mags. Possibly one of the tyres is defective, Front.
Thinking if it is backs, the whole car would shake. So it must be fronts. Either front rubber is defective or the mags are buckled. The guys at TyrePower reckons that’s not the case. I don’t know what else could be the problem. Can you guys offer some sort of assistance even if it is a wheel specialist place.
Thanks heaps.
Al
https://www.sau.com.au/forums/topic/55820-help-with-steering/
  • Replies 40
have a similar problem have a theory that its the front bushes that have started to show cracks probably cracked on insides first and worked way out thats why we couln figure it out my mechanic thinks i might be right am getting whole new suspension soon ( whiteline works kit) this better fix it
I was told by a mechanic that the suspension wouldn't affect just a steering, but the whole car. So I am inclined to say wheels. It's only the steering that shakes at early100. Even thought it was my discs. But that would only affect breaking. So the steering would pull to the dirrection of the front disc that is not grinded as much.
That's what I was told. I m getting the all machined and new brakes done aswell.
Some sort of Bendix. Any advice on Bendix while we are on the subject.
Bendix Advance front and rear plus all for machined disc's for $340.
I think that sounds ok. What do you think?
Al
ah yes true but mines only a theory and i need new suspension anywho i find i have a vibration between 85ish - 115ish no probs on strip or track vibration on acceleration deceleration and at steady pace mechanic sed the bushes that are cracked cop the full weight of the front of the vehicle and so may cause it but that theres no danger of s%$t hitting fan sort of thing
Hi,
Thanks heaps.
Al
How's the wheel alignment?
Alignment is fine ,
In that case it would only make the car push left or the opposite on the straight...
Depending on speed. I don't think the alignment would have anything to do with vibrations on steering at particular sped.
If I am wrong please guys explain how that is possible. As the vibrations are on 100 sharp and constant after that. Alignment would affect it on lover speed...
Yes?
If the alignment is out it can only show itself at certain speed ranges, As i have experienced in my Magna. I have a similar problem that at 70 - 90 kms i could feel a shudder but soon as i got over say 95kms it was smooth again. Saying that soon as i got under 70kms it was fine too it was only that range of 70 - 90kms.
So i got a wheel alignment done and it was fixed, i defiantly dont know much about cars or evan physics to explain it. Our problems sounded familiar so i though i would share, i hope i have helped.
Alignment is fine ,
Yes?
when I first got my "line", it would shudder when I reached around 115-120km/hr. The wheels were balanced, yet still that shudder. Didn't do much about it after that as I didn't often go that speed anyway.
When I discovered that the insides of the front tyres were wearing bad (excessive negative camber) I got the alignment checked and camber kit had to be installed as camber was way too much on the negative side. Negative camber will not necessarily give shudder as race cars use huge amounts of -tive camber, depending on track layout. Anyway the shudder is no longer there so I suspect something else in the alignment was out.
Pulling left or right doesn't necessarily have to be a symptom for the alignment to be out.
A failure in a tyre wall could be a possibility for shuddering or other tyre problems.
If you are able, try to swap your front wheels and tyres with one of your mates and take it for a spin. That way you will be able to discount the tyre factor.
If that checks out ok, then you might look at suspension bushes or even shockies.
Hope that helps
when my car got here from japan it had a bad vibration and the compliance workshop got all 4 wheels balanced and aligned however the problem still persisted. He dropped the tailshaft and he 3 uni-joints were worn and not moving freely he sent it off to some place in osborne park and they machined the joints and replaced them and all was fine again.
I had this problem a while ago...
Had 235 rears and 215 fronts, and i always had a vibration at about 110-120ish, went thru like 2 different sets of tyres and it was still there...
... then I got 255 rears, and 235 fronts..... were told the rims were slightly buckled while my tyre guy was doing the balancing, but put them on the car and it was perfect!
It might be your choice of rubber - but if you got two completely different brands both times it wouldn't be that?
i have same thing when i hit 120km :Paranoid:
Steering wheel wobbles after alignments, new rubber, new pads and new bushes ...... give up ..... i just cling to the steering wheel harder :P
hahaha so im not the onli one having problems :D my whole car is fkd, the people that did the custom boss kit thingy for steering wheel did it for it to be straight and now its gone wonky and stays wonky... its like tilted when u drive straight... with the car pushing to left when u drive straight, and it sometimes does that shaking shit that u guys are talkin about when goin through different speeds...
Guys I was told by all the tyre places and the mechanics that the suspension would not affect the steering, entire car would be affected. Not just an isolated steering problem. Most likely its the tyres. I have Goodyear, Venturas. $150each, brand new. Found out they have bumps in the circle fronface. When the wheel is rotating you can see the bumps on it. Even with the alignment done to 0.5g an all sides. I think I have crap tyres. It's gona be a Bad year with my GoodYEars. Hope I find something other than that solution.
And guys my steering is critical, it shakes 1 to 2 cm on both sides. at 100-120...not drivable.
Hope someone can recomend a good place.
Al
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
