most of you got PM's
The rear windscrean seal as in the exterior strip visible from the rear that covers the perimeter of the glass??
Yeah, that's the one I believe: I will double check tomorrow and let you know.
Lucien.
  • Replies 168
Posted Images
I'm looking for the plastic square that surrounds the passenger seatbelt on the side trim. u got it? will u ship it and how much u looking at for it???
I'm guessing the vents have been sold? and also are the plastic air thingys across the front of the dash available and not warped? cheers, pm me if u like.
I have checked and that's what I need: the thin moulding that goes around the rear windscreen.
Condition, pictures, price, blah.. ? :(
Cheers,
Lucien.
lwells, give me your e-mail address, so i can send you a pic.
The loom isn't coming out for a while. Sorry.
Pawley, do you need the upper part of the assembly or just the part on the glove box lid? I'll get back to you about the weather strip, once i find out what it is.
MatBoy, i do have the plastic square thing for the seat belts, and all the demister vents in god shape. Make me an offer.
cheer all.
What are the tailights like? Dont have to be perfect all over but lenses must be mint. The surround is getting modified to fit another car anyway.
How much are you after for the pair?
If you have piccies can you email to [email protected]
Cheers
Mika
You have PM. :(
I am also after the piece of plastic where the windscreen meets the bonnet: the water vein thing. This might help to explain it better:
AFAIK its the same for R32 GTS/-t and GT-Rs (anyone know different?)
LW.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
