that pipe is busted, however the front shocks are fine. $80 for the pair.
Hand brake lever it still there, but the cable is no longer attached as i am selling the cables seperately and i assumed that the guy needed that cables, but i'm not fully sure yet. You can buy the lever, and re attach your own cable fairly easily, just drill out the caulking join and spot weld the new cable in. if i don't sell that cable, i can reattach it for you if you like.
Make me offers for the quarter glass.
I have a set of 5 floor mats, but the drivers isn't in the best nick.
Bonnet cable with interior lever are still in good condition.
  • Replies 168
Posted Images
turns out firend didnt end up wanting the seats.
anyhow im after the trim in the boot, prety much the whole left side running up to the back of the seat and half of the trim on the right side (the part that covers the suspension tower). if you still have this how much you want and could you get a pic of it.
also i need a stock air box, cannot remeber if you had a pod or not. if you got this a price would also be nice
thanks
Jason
i have to idea how to measure up the tail lights. since they are not exactly square.
I do still have the bonnet cable. its yours for $20 +post. Pics of the mats may take a while cos i don't have a digicam.
the sunload sensor is still on the dash.
Linxus40 will have a PM
the lower dash surround, ie the one with the inserts used for switches has been sold along with the upper surround. If this is not what you were after please advise.
The dash pad is still available, however it has a bubble on the concave edge about between the pass and centre airvents. If you would still like pics, they can be arranged, however this may not adhere to your A1 prerequisite.
Yeh that was it :< Thanks anyway! If anyone else has one please PM me
  • 3 weeks later...
Hey chef, do u still happen to have the passenger front adjustable air vent by any chance? mine fell out today :D
Can you also email me with payment arrangements for the bonnet cable and interior lever please...my email it [email protected]
thanks heaps
Hey Chef,
Do u have the carpet that covers the spare tyre in the boot?
and also the centre air vents on dashboard?
and bonnet cable with interior lever?
Regards Joe
0402085323
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
