With so many threads about turbo upgrades for RB25's i thought itd be a good idea to start a thread that shows results only, as the results from various threads are scattered everywhere. Everyone has there own ideas about what power they want so obviously there isnt ONE perfect turbo upgrade for everyone.
Please post your RB25 dyno graphs only and state the following:
-Engine management
-Boost ran
-Fuel used (pump or special)
-significant engine mods (eg cams)
The idea of this thread is to be a quick reference to various turbo's performances on RB25's, not to be a discussion thread.
Thanks
(If this has been done already let me know, but didnt come up one in search.)
Check (if you live in usa): Costco Weekly Ad, or Supercheap Auto Catalogue.
https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/
:werd:
And does someone have a rb25det hi flow dyno result that they would also like to elaborate a little bit more on.
I dug this up from an old thread heres the thread with talk on the hks2535,2540 & 3037.
Click me
And here is the hks test chart for 2510,2530 on rb20det and the rest 2535,2540 on a R33 rb25det.Very interesting and has helped me to answer some of my quetions.All tests are done at 1 bar of boost.
Click me
There is a larger range than that there too with tests done on other cars as well.
here is my dyno results
mods
3" exhaust
pod filter
10psi boost
safcII
FMIC
BP Ultimate 98
stock standard turbo
We had an idling issue last week and to fix it the boys had to mess with the safc,
after getting the car to idle she ran 285hp but i didnt get a printout so i guess for this exercise i have 273hp
221RWKW mongrel unknown spec turbo from Rigoli.
The build consisted of:
Arias Forged Pistons 1.0 mm OS (1300)
GTR rods with fresh bolts (400)
ACL heat treated race bearings (120)
Balance, clean and O ring block etc. including straighten of crank and lightening. (1100)
GTR fuel pump (180)
Malpassi Rising Rate fuel reg (120)
Standard head gasket (90)
Hybrid Monster FMIC (700) piping (120) new Mig welder (700)
Autohouse Tsukasaki PFC (secret)
Dump and front combo 3" with Fujitsubo "Jasma" 3" stainless system and racing cat also fitted.
Click Here for dyno sheet
  • Like 1
Engine management - PFC
Boost ran - 1.4 Bar
Turbo - Garrett GT30
500cc injectors
Bosch 044 pump
HKS EVC 3
45mm Turbosmart External Wastegate
Custom Made Steam Pipe High Mount Turbo Manifold
Z32 80mm Air Flow Meter
HKS 600x300x76 Tube And Fine Intercooler
Custom 3inch Exhaust
HKS adjustable exhaust cam gearstock
etc etc etc
Fuel used - BP Ultimate
Stock Internals
The dyno graph i have is from MAS 04 as i cant find the selectamaz one where it went 324rwkw on a nice cool exterior located dyno.
  • Like 1
not home atm so cant post up dyno
1995 gts-t r33
turbo back zorst with hi flow cat
pod+ cai
hybrid fmic
10psi
stock turbo
stock ecu
optimax fuel
hybrid bov
173rwkw on a 29 degree temperature at 7:30pm lol about 6 months ago was last dyno
new results in a week with power fc, avcr (12psi), z32afm
ben...
1994 GTS25t
Hybrid TO3/TO4E (high flowed too - back cut ex wheel etc)
CP Forged pistons (8:1 CR)
Grex 1.6mm HG
ARP rod bolts
Port matched manifold
550cc inj and custom top feed rail
Malpassi reg
044 pump
K&N and custom inlet piping (nil AFM)
LT12 Microtech
FMIC
HKS EBC
Full 3" exhaust
The list could go on a LOT longer!
Also now have HKS cams (256 / 264)
Dyno pre HKS cams
Boost - Drops away to make peak power of 299.1rwkw @ 1.3bar
Dyno post HKS cams
Boost - Drops away even worse now! 270rwkw @ 1.1bar
Wanted - more $$$ to get a bigger turbo, run 1.5bar and make 300++rwkw :)
1995 gts-t
Stock turbo
pfc
gtr fuel pump
adj fuel press reg
3'' catback exhaust
ebc
Pod filter+partion
Small Hks front mount
Slipping stock clutch,leak in header/exhaust gasket.Cant remember what boost it ran...
12:1 afr's
182.0rwkw
:chop:
R33 gtst
Series 1
Stock turbo
Custom Dump pipe (Seperate wastegate pipe blended in), Hi flow cat manderal 3''
Stock ecu
Blitz LM cooler
8psi boost
K&N panel
Shootout mode dyno dynamics 175RWKW
Leaning out so couldn't rev out
AFR's went to 13.1 so backed off at 4900rpm
Will dyno in jan with pfc, pfc boost controller, upgraded fuel pump/nismo press reg.
This thread is great!
gcg st.1 450hp high flow turbo . gtr front mount cooler
aftermarket manifold, ces racing 3inch split dump, 3inch cat and exhaust.
link ecu, malpassi rising rate reg.
stock internals and stock cams.
224rwkws at 17.5psi, with more power to come just need new coil before i can run more boost. 224rwkws at 1.2bar shootout mode, dont have scanner to post sheet.
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
