R33GTST S1
Stock Turbo @ 12psi
Stock Internals
Front mount
Haltech ECU
3.75" Cat Back Exhaust, 3" In front of cat
190rwkw with decent clutch slippage
13.2sec Willowbank Raceway, No tread!
Upgrades In process right now, can post new dyno by Sunday Night if I have time to get out of the car :P
High flow stock turbo to GT3035 Standard, Install Nismo 740cc Injectors, New Clutch, Upgrading tyres to Falken GRB451's, block off POD filter with carbon box, upgrade dump. Real time map on dyno for a few hours to get power curve constant and kicking arse..
Just on another note, I changed my front back just before getting 190rwkw, a week earlier I had the stock series 1 front bar on, I achieve 178rwkw, by changing my bar to a new more flowing bar for the intercooler and pod I gained and extra 12rwkw.. no crap.. same temp same fuel same dyno machine. I found that very interesting.
93 R33GTST S1
Stock Turbo
Stock Internals
Stock intercooler
factory set boost
Power FC
pod filter(no CAI)
3" turbo back, high flow cat, 3" back, 4.5" tip - all stainless.
ss bov
New NGK iridiums (BCPR6EIX11- suited to RB20 but runs cooler with RB25 in our conditions)
caltex vortex (would have prefered ultimate but.....)
183.3rwkw (19/11/04)
93 R33 GTS-t S1
Stock turbo @ ~12psi
Stock internals
Custom front mount with garrett core
Wolf 3d version 4 ecu (no AFM)
3 inch turbo back exhaust with custom double dump
Pump fuel
187 rwkw
Next to come is GT28rs turbo with custom manifold, bigger fuel pump and injectors
gcg st.1 450hp high flow turbo . gtr front mount cooler
             aftermarket manifold, ces racing 3inch split dump, 3inch cat and exhaust.
             link ecu, malpassi rising rate reg.
             stock internals and stock cams.
             224rwkws at 17.5psi, with more power to come just need new coil before i can run more boost. 224rwkws at 1.2bar shootout mode, dont have scanner to post sheet.
We need that sheet big carl.Can you tell us what power it makes from 2000rpm-6500rpm.
I would like to know where it stands in the power delivery dept.
Here you go i will get you started just fill in the blanks.
Rpm
2000-
2500-
3000-
3500-
4000-
4500-
5000-
5500-
6000-
6500-
Cheers BigCarl.It's not compulsory:)
trust 33 ive plotted those figures of my dyno graph to the best of my ability, it goes as follows: 2000rpm- 35rwkws
2500rpm- 48rwkws
3000rpm- 84rwkws
3500rpm- 126rwkws
4000rpm- 150rwkws
4500rpm- 186rwkws
5000rpm- 210rwkws
5500rpm- 220rwkws
5900rpm-224rwkws power drops of at 6000rpm due to stock cams i think?
93 R33GTST S1
T3 turbo with 04 rear wheel
Stock Internals
600*300*76 intercooler
12psi
pod filter(no CAI)
3" turbo back, Standard emptyed cat, 3" back,
runing BP ultimate
300.2rwhp (about 222rwkw)
  • 2 months later...
'95 R33 GTS-t (S1.5 with 102,000km)
Micks Metalcraft FMIC
K&N Panel Filter
HKS Exhaust Cam Gear
Splitfire D1 Ignition Coils (gave me a solid 10rwkw)
Copper Plugs (0.8mm)
Dual-Stage Bleed Valve
Stock ECU
Stock Turbo (9psi - won't hold anymore)
Custom 3" Front/Dump pipe
Custom 3" Cat
Nismo 3" Cat-back Exhaust
Motul 4100 Oil
Fresh off the dyno only 2hrs ago.
198.5rwkw/266rwhp (before it started to ping)
Rpm - rwkw
2000 - 32
2500 - 60
3000 - 100
3500 - 116
4000 - 137
4500 - 145
5000 - 155
5500 - 185
6000 - 180
6500 - 198
7000 - 190
Now if only I could get the boost to hold 11-12psi and stop the pinging i'd be well into the 200's on the stock turbo/ECU :D:)
s2 Rb25det
K&N pod filter with cold air intake
FMIC
3 inch full exhaust (including wastegate/turbo integrated dump pipe)
Power FC
R33 gtr fuel pump
Sard fuel pressure reg
Blitz Dual SBC
std engine/turbo @ 1.1bar
210rwkw on 29deg day (Tilbrooks)
I have
Stock Turbo - 12psi
Stock Motor
3 inch split Dump, front pipe
Hi Flo Cat
Muffler
Partitioned Pod Filter
600x300x75 Intercooler with stock Plenum
POWER FC + HC (best investment)
10% Mix of Toluene
210rwkw
420nm Torque
Very quick, and nice consistant powercurve.
Mine's on the way...currently waiting for the power FC and all will go at the same time as the others...i currently have sitting in my garage are :
T70 turbo with custom dump
HKS 40mm external wastegate
SS top mount manifold
nismo 550 injectors
bosch 044 fuel pump
already in the car are :
Greddy FMIC
nismo air filter
trust boost controler
cusco high flow cat
4' SS catback and 3 from turbo to cat
i will need to replace my Clutch once the new set up is installed..that's for sure...so hopefully i get a good figure from it...will keep you guys posted.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
