My car is fairly standard yet making good power.
MODS:
3" zorst
FMIC (HKS, strange item, both inlet and outlet on same end tank)
Cold air induction + HKS pod
Some sort of chip, as it flies past the rev-limiter and has way too nice of an AFR curve.
standard turbo running around .9-1.0 bar
207.8rwkw with a 13.5@108mph
sorry about dyno size but
edit: peak power is at 7400rpm
GTR Intercooler
HKS Super-dragger, Hi-Flo Cat, HPC coated dump pipe
rb20 wastegate actuator, bleed valve combo for 12psi
stock turbo
iridium sparkies gapped to .8mm
98 RON BP Ultimate
ex cam gear 4 degrees retard
hks pod with cold air partition
Power FC
210RWKW in Shootout Mode - and pulls like a train on boost !!
hey guys im new here but thought i might share my powers too.
4dr r33 pumped 251.1 rwkw @ 15psi power run only
power fc
xtr gtst upgrade turbo (pretty suprised how efficient they are)
bosch 600hp pump
highflowed injectors
nismo reg
3'zorst
more tuning needed (expecting 265-270 on same boost and around 280-290 on 18psi although dont know if its wise)
Apexi RX6 550HP Turbo
Apexi Rb25 Forged bottom end kit.
Apexi 260 Degree Cams
Wolf3D Management
393hp@ 14psi
418hp@ 18psi
Boost comes on at 3000 RPM
15psi @ 4200 RPM
18psi @ 4500 RPM
Just tested it last week at Kwinana Motorplex 11.75 @ 122 MPH
Can post up the graph tonight
I'm still trying to sort out some tuning issues but I saw 234 rwkw from my car a couple of days ago.
GCG highflow
CES split dump
Fujitsubo 3" cat back with 2 mufflers for quietness
panel filter in stock air box
480cc Nismo injectors
ROM tune from Powerplay (still to be sorted)
About 12-13 psi at peak power (also have boost controller issues)
just thaught ide add to stock turbo r33 gtsts making over 200rwkw. because i think people need to realize its not as uncommon or amazing as alot of people think.
3in turbo back exaust, high flow cat
std turb 11psi
pod with cai
ex cam gear -3deg
hks type s fmic
std ecu+ safc 2
208.8rwkw and done a 13.4 on its first run at wsid
bottom end rebuild
forged pistons
tomei 256潞 cams
EBC @ 10psi
SAFC
full 3.5" (stock dump)
stock cooler (Hybrid kit waiting to go on)
stock turbo
NOT in shootout mode 166rwkw
as an example I got 178rwkw before the rebuild with a tired motor, in SO mode
93 R33 GTST
stock turbo @ 12psi
stock ECU, injectors, fuel pump
3" turbo back exhaust w/ cat pipe
Pod with partition and CAI
Hybrid copy FMIC with backyard piping :rofl:
SAFC2
200.9 rwkw
Well I'm still not entirely happy with things and now my transmission is crapping itself.
Anyway here are the dyno sheets.
Mods.
Stock airbox with Nismo panel filter
GCG highflow turbo
CES split dump/front pipe
3" cat
3" Fujitsubo cat back with 2 mufflers
Auto - chipped ECU
R34 GTR fuel pump
R34 GTR regulator
around 12psi boost.
My next setup,
engine with less compression
t88-33d @ 1.6bar
custom manifold
hi flowed injectors
msd ignition
microtech
forward facing standard plenum
cooler
bosch fuel pump and reg
The first dyno sheet is in non shoot out mode,
the second is in shoot out mode on 1.3bar and a cracked exhaust manifold.
GTT at Stage1 (exhaust etc)
Trust TD05-18g
14psi
Standard ECU
98RON fuel
Figure is HP at the wheelhubs on a Dynapak
Same car with same turbo but FMIC/Inj/Pump/ECU etc
TD05-18g
17.5psi
PowerFC
98 RON fuel
