just had my car dyno!
450hp gcg turbo
550cc injectors
z32 afm
fmic
pfc
3" exh turbo back
greddy filter
nismo pump
nismo reg
hks evc 3
200rwkw at 10 psi
220rwkw at 1bar
the tuner thinks that it would get more power at 15 psi by looking at the 10 psi boost. we have tried to boost to 1.2bar but it dropped back to 15 psi. He reckoned that it was leaking pressure somewhere and possibly the stock BOV! any suggestions would be appreciated!! :rant:
It does sound like you need to fiddle with the cam gear.  I have 228rwkw at 12-13 psi, same turbo.  This is an auto though so that equates to a bit more.
Abo:
what degree did you set your exh timing? The thing is i got 200rwkw at 10psi but as i increase boost to 14psi i got 224rwkw but when increased another psi i got less power! Basically the graph power is like a straight line! note also i have turbo surge at 3500rpm as well! :whatsthat
3000: 85rwk
3500: 115rwkw
4000: 138rwkw
4500: 156rwkw
5000: 175rwkw
5500: 193rwkw
6000: 205rwkw
6500: 217rwkw
6700: 220rwkw
7000: 215rwkw
do you still use stock BOV?
  • 3 weeks later...
33gtst S1 94
Stock turbz
Custom FMIC
9psi
Air filter
3'' xzorst from turbo
SSQV
stock internals
standard ecu
204 rwkw
dude rekons i would make bout 215rwkw at 12-13psi this is pre good on stock turbo me thinks
will post my dyno sheet if someone tells me how as im a computer retard
R33 GTS-T
TD06-20G turbo on high mount manifold
Tomei cams and cam gears
Forged pistons
650cc Injectors
Blitz external wastegate and screamer pipe
Blitz fmic.
Splitfire coils
Haltech E11v2.
On pump fuel
IPS460 T04e (460hp)
Wolf3dv4
Walbro Pump
Malpassi
Garrett 300x600fmic
3inch zorst from turbo
242rwkw @ 16psi
Dodgy dyno sheet as the clutch was slipping as boost came on then grabbing on at higher revs... made for crazy power dips along the curve.
Stock injectors were close to max at this power. New injectors (when money permits) will allow 18-20psi which will bring this turbo more into its efficiency range as at the moment it still has a lot left in it.
Hi
Car: Impul R33r Sedan
Mods are as follows:
- HKS 2835 Pro Spec S with HKS Actuator
- Apexi PFC with Boost Controller
- Nismo 550cc Injectors
- Z32 Air Flow Meter
- R33 GTR Intercooler
- R33 GTR Fuel Pump
- NPC Nismo Style Pressure Plate and Ceramic Clutch
- 3' Dump and exhaust
- 98 BP Ultimate
Made 230.7rwkw at 17psi, could have got more, but didnt want to lean on the engine too much. Nice and safe.
i was pullin 200 kw on the stock turbo
dyno is in the hks gt2530 thread
Thizzle,
I understand you got 250rwkw with a HKS GT-RS, PFC, 1 bar,FMIC.
What are your other mods? if you have any, such as:
injectors?
fuel pump?
FMIC size+brand?
Pod/Panel filter?
Exhaust(size & name)?
Top/Bottom-end....Stock internals?
This information would be most appreciated. Thank you.
Bill
late reply havent been on much lately...
man thats a long time ago i currently making 301.6 rwkw on the tiny gt-rs on 1.38 bar boost.. i got some hks cams and head gasket and a retune...ill scan dyno later..stock internals,ALL parts u asked about are HKS..cool turbo for street use in sydney..
dyno attached now.... best run is runfile007...
Bought my Skyline two months ago and got it serviced and dyno'ed a few weeks back. It outputs 142.7kW at the rear wheels. Was very impressed with this output as it is only a stock car.
I plan to do some performance upgrades to it once i've saved up enough.
My first post on this site. :D Looking forward to posting many more.
R32 gtst 93 rb25
Apexi PFC
Tomei cams
Arais forged pistons
gtr rods
550cc injectors
Z32 airflow meter
FMIC
3.5inch Exuast
HKS 3037 proS
HKS ssq blow off valve
Yet to do the final dyno run but it is sure to make over 280rwkw on 1.2 bar
With a bit of 116octane she should make about 330rwkw on around 1.7 bar
i have an R33 S2
- stock cooler
- stock ECU
- stock turbo
- apexi power intake
- split dump and 3" front
- hollow cat :D
- HKS hi power 3.5"
- 10psi
made 170rwkw. with misfire on 11-12psi, stopped the run, coils earthing out
taped coils with nitto elec tape = no missfire, yet to dyno
PFC on the way, then what sort of grunt would it make with 12psi and FC? anyone?
i have an R33 S2
- stock cooler
- stock ECU
- stock turbo
- hollow cat ;)
- HKS hi power 3.5"
- 10psi
Does taping the coil packs only help when they have obvious cracks in them?? I'm having trouble with my RB25, have searched alot and tryed a few different things but still got the misfire up high (4500 onwards)
Might aswell add mine too I suppose.
RB25
-Hybrid turbo
-fmic
-exhaust
-haltech
-custom plenum
-600HP fuel pump
-249RWkw @ 12.5 Psi
Dyno done over a year ago before buying the car, so it needs a tune badly. Got some injectors to go in and fix the misfire then might turn the boost up a bit more
hey
series 2 gtst 96
stock turbo
no f.m.i
3inch(apparently) stainless turbo back
H.K.S air filter
blitz sbc
on 10 p.s.i( wish i could put the dyno sheet on dont know how) holds boost throughout entire rev renge 179.8 k.w
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
