just had my car dyno!
450hp gcg turbo
550cc injectors
z32 afm
fmic
pfc
3" exh turbo back
greddy filter
nismo pump
nismo reg
hks evc 3
200rwkw at 10 psi
220rwkw at 1bar
the tuner thinks that it would get more power at 15 psi by looking at the 10 psi boost. we have tried to boost to 1.2bar but it dropped back to 15 psi. He reckoned that it was leaking pressure somewhere and possibly the stock BOV! any suggestions would be appreciated!! :rant:
It does sound like you need to fiddle with the cam gear.  I have 228rwkw at 12-13 psi, same turbo.  This is an auto though so that equates to a bit more.
Abo:
what degree did you set your exh timing? The thing is i got 200rwkw at 10psi but as i increase boost to 14psi i got 224rwkw but when increased another psi i got less power! Basically the graph power is like a straight line! note also i have turbo surge at 3500rpm as well! :whatsthat
3000: 85rwk
3500: 115rwkw
4000: 138rwkw
4500: 156rwkw
5000: 175rwkw
5500: 193rwkw
6000: 205rwkw
6500: 217rwkw
6700: 220rwkw
7000: 215rwkw
do you still use stock BOV?
  • 3 weeks later...
33gtst S1 94
Stock turbz
Custom FMIC
9psi
Air filter
3'' xzorst from turbo
SSQV
stock internals
standard ecu
204 rwkw
dude rekons i would make bout 215rwkw at 12-13psi this is pre good on stock turbo me thinks
will post my dyno sheet if someone tells me how as im a computer retard
R33 GTS-T
TD06-20G turbo on high mount manifold
Tomei cams and cam gears
Forged pistons
650cc Injectors
Blitz external wastegate and screamer pipe
Blitz fmic.
Splitfire coils
Haltech E11v2.
On pump fuel
IPS460 T04e (460hp)
Wolf3dv4
Walbro Pump
Malpassi
Garrett 300x600fmic
3inch zorst from turbo
242rwkw @ 16psi
Dodgy dyno sheet as the clutch was slipping as boost came on then grabbing on at higher revs... made for crazy power dips along the curve.
Stock injectors were close to max at this power. New injectors (when money permits) will allow 18-20psi which will bring this turbo more into its efficiency range as at the moment it still has a lot left in it.
Hi
Car: Impul R33r Sedan
Mods are as follows:
- HKS 2835 Pro Spec S with HKS Actuator
- Apexi PFC with Boost Controller
- Nismo 550cc Injectors
- Z32 Air Flow Meter
- R33 GTR Intercooler
- R33 GTR Fuel Pump
- NPC Nismo Style Pressure Plate and Ceramic Clutch
- 3' Dump and exhaust
- 98 BP Ultimate
Made 230.7rwkw at 17psi, could have got more, but didnt want to lean on the engine too much. Nice and safe.
i was pullin 200 kw on the stock turbo
dyno is in the hks gt2530 thread
Thizzle,
I understand you got 250rwkw with a HKS GT-RS, PFC, 1 bar,FMIC.
What are your other mods? if you have any, such as:
injectors?
fuel pump?
FMIC size+brand?
Pod/Panel filter?
Exhaust(size & name)?
Top/Bottom-end....Stock internals?
This information would be most appreciated. Thank you.
Bill
late reply havent been on much lately...
man thats a long time ago i currently making 301.6 rwkw on the tiny gt-rs on 1.38 bar boost.. i got some hks cams and head gasket and a retune...ill scan dyno later..stock internals,ALL parts u asked about are HKS..cool turbo for street use in sydney..
dyno attached now.... best run is runfile007...
Bought my Skyline two months ago and got it serviced and dyno'ed a few weeks back. It outputs 142.7kW at the rear wheels. Was very impressed with this output as it is only a stock car.
I plan to do some performance upgrades to it once i've saved up enough.
My first post on this site. :D Looking forward to posting many more.
R32 gtst 93 rb25
Apexi PFC
Tomei cams
Arais forged pistons
gtr rods
550cc injectors
Z32 airflow meter
FMIC
3.5inch Exuast
HKS 3037 proS
HKS ssq blow off valve
Yet to do the final dyno run but it is sure to make over 280rwkw on 1.2 bar
With a bit of 116octane she should make about 330rwkw on around 1.7 bar
i have an R33 S2
- stock cooler
- stock ECU
- stock turbo
- apexi power intake
- split dump and 3" front
- hollow cat :D
- HKS hi power 3.5"
- 10psi
made 170rwkw. with misfire on 11-12psi, stopped the run, coils earthing out
taped coils with nitto elec tape = no missfire, yet to dyno
PFC on the way, then what sort of grunt would it make with 12psi and FC? anyone?
i have an R33 S2
- stock cooler
- stock ECU
- stock turbo
- hollow cat ;)
- HKS hi power 3.5"
- 10psi
Does taping the coil packs only help when they have obvious cracks in them?? I'm having trouble with my RB25, have searched alot and tryed a few different things but still got the misfire up high (4500 onwards)
Might aswell add mine too I suppose.
RB25
-Hybrid turbo
-fmic
-exhaust
-haltech
-custom plenum
-600HP fuel pump
-249RWkw @ 12.5 Psi
Dyno done over a year ago before buying the car, so it needs a tune badly. Got some injectors to go in and fix the misfire then might turn the boost up a bit more
hey
series 2 gtst 96
stock turbo
no f.m.i
3inch(apparently) stainless turbo back
H.K.S air filter
blitz sbc
on 10 p.s.i( wish i could put the dyno sheet on dont know how) holds boost throughout entire rev renge 179.8 k.w
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
