just had my car dyno!
450hp gcg turbo
550cc injectors
z32 afm
fmic
pfc
3" exh turbo back
greddy filter
nismo pump
nismo reg
hks evc 3
200rwkw at 10 psi
220rwkw at 1bar
the tuner thinks that it would get more power at 15 psi by looking at the 10 psi boost. we have tried to boost to 1.2bar but it dropped back to 15 psi. He reckoned that it was leaking pressure somewhere and possibly the stock BOV! any suggestions would be appreciated!! :rant:
It does sound like you need to fiddle with the cam gear.  I have 228rwkw at 12-13 psi, same turbo.  This is an auto though so that equates to a bit more.
Abo:
what degree did you set your exh timing? The thing is i got 200rwkw at 10psi but as i increase boost to 14psi i got 224rwkw but when increased another psi i got less power! Basically the graph power is like a straight line! note also i have turbo surge at 3500rpm as well! :whatsthat
3000: 85rwk
3500: 115rwkw
4000: 138rwkw
4500: 156rwkw
5000: 175rwkw
5500: 193rwkw
6000: 205rwkw
6500: 217rwkw
6700: 220rwkw
7000: 215rwkw
do you still use stock BOV?
  • 3 weeks later...
33gtst S1 94
Stock turbz
Custom FMIC
9psi
Air filter
3'' xzorst from turbo
SSQV
stock internals
standard ecu
204 rwkw
dude rekons i would make bout 215rwkw at 12-13psi this is pre good on stock turbo me thinks
will post my dyno sheet if someone tells me how as im a computer retard
R33 GTS-T
TD06-20G turbo on high mount manifold
Tomei cams and cam gears
Forged pistons
650cc Injectors
Blitz external wastegate and screamer pipe
Blitz fmic.
Splitfire coils
Haltech E11v2.
On pump fuel
IPS460 T04e (460hp)
Wolf3dv4
Walbro Pump
Malpassi
Garrett 300x600fmic
3inch zorst from turbo
242rwkw @ 16psi
Dodgy dyno sheet as the clutch was slipping as boost came on then grabbing on at higher revs... made for crazy power dips along the curve.
Stock injectors were close to max at this power. New injectors (when money permits) will allow 18-20psi which will bring this turbo more into its efficiency range as at the moment it still has a lot left in it.
Hi
Car: Impul R33r Sedan
Mods are as follows:
- HKS 2835 Pro Spec S with HKS Actuator
- Apexi PFC with Boost Controller
- Nismo 550cc Injectors
- Z32 Air Flow Meter
- R33 GTR Intercooler
- R33 GTR Fuel Pump
- NPC Nismo Style Pressure Plate and Ceramic Clutch
- 3' Dump and exhaust
- 98 BP Ultimate
Made 230.7rwkw at 17psi, could have got more, but didnt want to lean on the engine too much. Nice and safe.
i was pullin 200 kw on the stock turbo
dyno is in the hks gt2530 thread
Thizzle,
I understand you got 250rwkw with a HKS GT-RS, PFC, 1 bar,FMIC.
What are your other mods? if you have any, such as:
injectors?
fuel pump?
FMIC size+brand?
Pod/Panel filter?
Exhaust(size & name)?
Top/Bottom-end....Stock internals?
This information would be most appreciated. Thank you.
Bill
late reply havent been on much lately...
man thats a long time ago i currently making 301.6 rwkw on the tiny gt-rs on 1.38 bar boost.. i got some hks cams and head gasket and a retune...ill scan dyno later..stock internals,ALL parts u asked about are HKS..cool turbo for street use in sydney..
dyno attached now.... best run is runfile007...
Bought my Skyline two months ago and got it serviced and dyno'ed a few weeks back. It outputs 142.7kW at the rear wheels. Was very impressed with this output as it is only a stock car.
I plan to do some performance upgrades to it once i've saved up enough.
My first post on this site. :D Looking forward to posting many more.
R32 gtst 93 rb25
Apexi PFC
Tomei cams
Arais forged pistons
gtr rods
550cc injectors
Z32 airflow meter
FMIC
3.5inch Exuast
HKS 3037 proS
HKS ssq blow off valve
Yet to do the final dyno run but it is sure to make over 280rwkw on 1.2 bar
With a bit of 116octane she should make about 330rwkw on around 1.7 bar
i have an R33 S2
- stock cooler
- stock ECU
- stock turbo
- apexi power intake
- split dump and 3" front
- hollow cat :D
- HKS hi power 3.5"
- 10psi
made 170rwkw. with misfire on 11-12psi, stopped the run, coils earthing out
taped coils with nitto elec tape = no missfire, yet to dyno
PFC on the way, then what sort of grunt would it make with 12psi and FC? anyone?
i have an R33 S2
- stock cooler
- stock ECU
- stock turbo
- hollow cat ;)
- HKS hi power 3.5"
- 10psi
Does taping the coil packs only help when they have obvious cracks in them?? I'm having trouble with my RB25, have searched alot and tryed a few different things but still got the misfire up high (4500 onwards)
Might aswell add mine too I suppose.
RB25
-Hybrid turbo
-fmic
-exhaust
-haltech
-custom plenum
-600HP fuel pump
-249RWkw @ 12.5 Psi
Dyno done over a year ago before buying the car, so it needs a tune badly. Got some injectors to go in and fix the misfire then might turn the boost up a bit more
hey
series 2 gtst 96
stock turbo
no f.m.i
3inch(apparently) stainless turbo back
H.K.S air filter
blitz sbc
on 10 p.s.i( wish i could put the dyno sheet on dont know how) holds boost throughout entire rev renge 179.8 k.w
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
