96 S2 R33 GTS-T
RB25DET
Stock turbo @ 9 psi
Apexi AVC-R electric boost controler
Split fire coilpacks
3.5" HKS Exhaust with high flow dump pipe.
Front mount intercooler
HKS Pod
DYNO was done by old owner.
186.3kw
rb 26 crank
rb26 rods
86.5mm forgies
1.6mm headgasket
gcg highflow with vg30 exhaust housing
600x300 cooler
bosch 040
stock computer n injectors
346.1hp(258kw) at wheels on 15psi
Edited by sweetr33
R33 SII
- stock turbo @ 10 psi
- full exhaust (turbo back)
- pod filter
- walbro 500-600hp fuel pump
- sard 550cc injectors
- power fc
- fmic
= 204.0 rwkw
(ALSO DISCOVERED LATER THAT NIGHT HOLE IN SILCICONE TUBE ON COOLER PIPING)
Edited by YLD-180
r33 gts-t 95 model
Slide Hi flow Turbo running 13psi
Tomei 1.2mm Head Gasket
Greddy Profec B Spec II
FMIC
TRUST zorst
Apexi Power FC
Stock Injectors
232.7rwkw but wastegate actuator was playin up, will give it another shot with Poncams and a new 1 bar actuator
1997 RS4 Stagea RB25DET
(Auto) - 4 Wheel Drive
GCG HIFLOW TURBO
HYBRID FMIC
3" EXHAUST/DUMP/CAT AND 3.5"MUFFLER
WALBRO 500HP INTANK FUEL PUMP
E-BOOST EBC 15PSI
POD FILTER WITH COLD INDUCTION
203 AWKW! (STOCK ECU)
*AFR's Between 12 and 11
Dyno.doc
R33 GTST Skyline - 365rwhp or 278rwkw
G-Max Wheels rear: 18x9.5 with 265’s front: 18x8.5
Tein hight and rebound adjustable suspension
Full 3inch custom exhaust with Magic Cat and twin Mufflers
T70 turbo on X-Force highmount manifold
Turbosmart 48mm Pro-Gate wastegate
100mm think Front Mount Inter Cooler
Blitz blow off valve
Sard fuel pressure Regulator
Sard 550cc injectors
Walbro 500 horsepower fuel pump
Motec Enginge Management System
Exceedy 5 puck clutch
Pod air filter
Oil catch can
Thermo fan
DBA 4000series sloted disks alround with braided lines
Braided fuel-line, blow-by, breather and radiator overflow hoses
New chrome radiator overflow tank
Gates Racing radiator hoses
I took out the unrelated mods to that list. The car was dynoed in Brisbane before I bought her. She is getting forged pistons, rods and cams put into her at the moment. When I dyno her up here again by the end of the year I will post results. Sorry about the bad pic.
R32 GTST Powered by NEO RB25
- Custom built high mount Garret GT35r turbo
- Fully forged engine rebuild with all the good shit
- Standard Injectors and GTR fuel pump (for the run in)
- Microtech MT8 ECU
- Optimax 98 ron
Pulled close to 200rwkw's on 3psi of boost
*will post dyno sheet when it is made available to me.
Edited by FSTR32
Completely stock motor internally
T04r
sheetmetal intake
custom header
SDS EFI
20 psi on 93 octane
489 rwhp (364 rwkw) @ 7500 rpm
~11.7:1 a/f
Expecting around 600 rwhp with some good gas and more boost.
JT
Edited by J Taylor
R33 series 2
The last dyno seemed rather out (218kw) so I had the car ran again on a different dyno
9PSI
turbo back 3inch
fmic 600*300*75
bp 98
pod
KSP retuned stock ecu
and not the best spark plugs need to be replaced
174.8 @ 6160rpms
rather rich air/on 10.7
R33 series 2
9PSI
turbo back 3inch
fmic 600*300*75
bp 98
pod
174.8 @ 6160rpms
rather rich air/fuel on 10.7
R33 series 2
9PSI
turbo back 3inch
fmic 600*300*75
bp 98
pod
174.8 @ 6160rpms
Let the saga begins:
Sept 2002: 138rwkw
R33 S1 Auto
- 100% stock 7psi
May 2003:155rwkw
R33 S1 Manual
- Auto to manual conversion, std auto 1.43:1 diff retained
- 3" Trust MX Exhaust
- Turbosmart bleed valve 9psi
- Auto ECU (gave weird power dips - ECU still think there is an auto box and allowed for gearshift points)
Jun 2003:155rwkw
- Boost still 9psi (dodgy Turbosmart bleed valve spikes when set higher)
- Std S1 Manual ECU (replacing auto ECU - smoother power curve)
- Apexi panel filter in stock airbox
- Car was having weird problem not wanting to make more power, found out it's dying std fuel pump
Aug 2004:192.8rwkw *shootout*
- HKS EVC EZ-II boost controller 10psi (replacing dodgy Turbosmart bleed valve)
- Apexi SAFC
- ARC FMIC turn-flow style
- Bosch 975 fuel pump (replacing dying std fuel pump)
- Still running std injectors, std turbo
Jun 2005:188.8rwkw - this is not shootout mode, dyno reads a bit lower
- still 10psi boost
- Apexi PowerFC (replacing Apexi SAFC)
- Weird tuning resulted in low kw output, turned out that SAFC was not removed yet (forgot to do as it's hidden in glove box)
Jun 2005:191.9rwkw
- still 10psi boost
- Apexi PowerFC "safe" tune (SAFC is removed so no more "war" between ECUs)
- Still running std injectors, turbo and AFM
Aug 2006: 229.1rwkw *shootout* (Almost 4 yrs since 1st popped its dyno-virgin rear wheels)
- Boost now raised to 16psi on my EVC EZ-II
- HKS GT2535 0.65 A/R turbo (replacing std turbo)
- Z32 AFM (replacing maxed out std AFM @ 206rwkw)
- Still running std injectors, fuel pressure reg, stock airbox with Apexi panel filter
- Apexi PowerFC tuned by a MOTEC experienced tuner @ Chasers
- New set of NGK spark plugs, gapped at +/- 0.7mm (replacing the old OWS plugs)
Future: ???rwkw
- Recommended by tuner to replace std coils with Splitfire coils to give more consistent spark
- Perhaps raise the boost another few clicks after new coils are fitted
OH, and I forgot to mention - All those tunes above are done on Optimax 98. I may have once or twice switched to BP Ultimate or Mobil Synergy9000, but 95% of the times are on Optimax.
My mates series1 R33 GTSt stock with
- full exhaust bar stock dump pipe
- 600x300x75 FMIC
- K&N POD
- Earthed solinoid mod (constant 7-8PSI)
Pulled 220rwhp or 164rwkw flat off the rollers with BP Ultimate
Not too bad i thought anyway
Edited by Ganador
Series 2 Nissan stagea RS Four S
...mods are
front mount
split dump/engine pipe
catco 5" metal inside cat with 3" cone reducers
blitz NUR spec 3" catback exhaust
walbro fuel pump
power fc
K&N panel filter in standard air box
GREDDY FMIC
G.C.G HIGHFLOW TURBO
CUSTOM TURBO BACK EXHAUST
APEXi POWER FC
GREDDY EBC
BLITZ BOV
TOMEI FUEL PUMP
SARD FPR
Z32 AFM
CUSCO CATCH CAN
made 327 rwhp on 17psi
gettin injectors in when turbo is back
and then retune
see what i make
need to scan dyno graph
but 93 gtst
standard internals
standard turbo
standard pump and injectors
blitz ehaust decatted
blitz cooler
splitfire coils
link ecu
211kw @ 9psi of turbo smart bleed valve
R33 S2 GTS-t: Power FC, HKS 2530kai turbo, Pod filter with cai, Z32 afm, 1.1bar (16lb) boost controlled by Blitz DSBC Spec R controller, HKS fmic, GTR bov, Bosch 040 pump, Sard fpr, Nismo 555cc injectors, Splitfire coils, split front/dump pipe, highflow cat, 3inch cat back exhaust. 218rwkw.
20/12/06 Re-tune: 244.9rwkw at 16lb. 200kw by 4300rpm. No power gain beyond 6000rpm.
Edited by maxr33
