Rb25 Turbo Upgrade, All Dyno Results
Nacho Vidal
1995 R33 GTS-t
Stock internals.
Garrett GT30/40RR Turbo
High stainless mount extractors (some cheap Chinese copy)
TIAL 38mm wastegate
TIAL blow off valve
3" Exhaust Turbo to tip.
Hybrid intercooler.
Custom alluminium plenum
Siemenns 600cc injectors
Splitfire coils
Tial Fuel rail
Bosch internal fuel pump
Bosch external fuel pump with surge tank
Microtech LT-12 ECU
OS Giken twin plate ceramic clutch
234kw @ wheels on 9 lbs (not sure about torque)
294kw @ wheels on 18 lbs, 714nm of torque (in 33 degree weather) in 3rd gear at about 4200rpm
  • 3 weeks later...
r33 S2
Bosch fuel pump,
forged pistons,
shaved heads,
metal head gasket,
19 pound drops to 16 over range,
4 inch turbo back exhaust (trust) no cats,
Apexi power FC
High flow turbo
Trust FMIC
217 rwkw can go a fair bit higher but unstable with stock injectors
1996 S2 gts-t
stock turbo
stock ecu with safc
3 inch apexi turbo back with custom dump pipe
Trust pod in custom steel enclosure with 90mm direct cold air pipe
Blitz electronic DSBC
apexi rev/speed meter
Blitz BOV
Apexi FMIC
Iridium plugs
Exedy HD cushion button clutch
DD shootout mode: 208.3 rwkw at 12psi on BP Ultimate
All plotted from the same dyno run. Posted for interest's sake. The heading stuffed up on the torque printout - don't know why.
Stock RB25DET, GT35, PFC, Eboost2, C4 Auto with very loose converter - Nitrous Oxide still to come :glare:
R33 GTST Series 2
Standard Turbo
Standard ECU
Boost - 10psi
Front/Dump pipe
HKS Super Dragger
Apexi GT Spec FMIC
Airbox w Apexi Panel
Nismo Fuel Pump
Splitfires
166.2kW
RB25DET
Garrett GT35/40R int wastegate low mount
Hi flowed injectors (measured 504cc)
Fuel pump
Intercooler
Spitfire coils
3inch dump pipe
Turbosmart BOV
Power FC
Greedy Profec-B electronic boost controller
std exhaust and inlet manafolds
std internals
1.1 bar 259kwrw
20050610_Bris_Tuning_Dyno_258.76kw_GT3540.pdf
RB25DET
Haltech E6K
GT35/82
600x300x100 FMIC
Nismo 740cc's
3"Exhaust
Fuel pump (unsure what size)
Custom plenum
xf throttle body
Greddy Profec B II
Tial 44mm gate
6Boost manifold
Car was having troubles with the fuel so it's going back in Monday to sort that out and make some more power.
Rev limit set at 6000Rpm
The car is a 1993 R32 GTS-t, mods are:
S1 RB25DET swap
El cheapo T70 turbo @ 23 psi
El cheapo 38 mm gate
El cheapo high mount manifold
Bosch 044 in-tank job
3" straight through zorst
ARC front mount intercooler
Pod, BOV, etc
Stock internals, stock injectors, stock fuel pressure reg, stock ecu (tuned by Garage Saurus when in Japan, but).
The car made 196.7 rwkw @ 14 psi, back before we had the 3" on it (had stock exhaust with chopped/changed bits and big restrictive dents)
The 3" brings minimum boost up to 23 psi (tiny 38mm gate is fully opening, can't bypass enough exhaust, strange).
Fuel hasn't been an issue yet, the tuned ecu coupled with the RB20/25 airflow meter sees the airflow meter max out and the ecu starts dumping all the fuel it can, pretty much 100% injector duty cycle.
On the dyno run we were seeing 10:1 AFRs pretty much the minute manifold pressure went positive hey.
Now that we've got the 3", and the boost at 23 psi it's running well fast, seat of the pants dyno suggests around the 250 rwkw mark, with boost hitting HARD at about 4000 rpm, watering off toward the high revs (maybe down to about 20 - 21 psi). Blows away XR6 Turbos with ease.
Bit of fun! Microtech is next on the list, followed by RB20 fuel rail and some top feed 550cc injectors or something like that. Leaning up the mixture should help us make a fair bit more power, I'm hoping.
Edited by initialed
94 R33 GtS-T ALSD
Stock turbo
ARC Intake
Blitz SSBOV
V-Power 99 Ron
RPS Heavy Organic clutch
Stock everything else
8psi boost
254bhp@6400rpm
217lb/ft@4800rpm
Made 210 wheel horse power
Edited by Stevie_R33
R33GTST
Slide stage 3 Hi-flow - max oversize, RB25 housing.
Walboro pump
China cooler
Turbotech boost controller
Deatschwerks 555cc injectors
Z32 AFM
Split front/dump and 3" exhaust
Power FC
18psi
304rwhp
Was expecting a bit more, but the tune is nice and safe, so meh
Mods:
Garrett GT2871R 48T high flow @ 13psi
PFC + Datalogit
Splitfire coils
NGK BKR7E copper plugs, gapped to .85
Bosch 040 pump
S15 Silvia spec 440cc injectors
Pod filter + cold air feed
2.5 inch split dump (cheap Chinese job) + 3 inch front pipe, 80mm Blitz cat-back with 2.5 inch restrictor at tail pipe
FMIC Chinese
room for improvement at top end - nosing over a bit quick. Probably tied in with richness and getting to the end of flow capacity for this compressor.
mid range improvement likely to come with adjustable exhaust cam gear.
very driveable unit
Edited by Dale FZ1
1995 Series 1.5 GTS-t
stock turbo
stock internals
standard boost
3" xhuast cat back
FMIC
pod and CIA
turbosmart type 2 BOV
167.4 rwkw
definatley a good platform to build
next to come is
turbo
fuel pump
ecu
and injectors
R33 GTS-T 1994 Series 1
5 spd Manual
Mods
Bosch Internal Fuel Pump
Splitfire Coil Packs
Batmbl Split Front/Dump Pipe
3inch exhaust catback
Apexi Pod Filter
GFB Bleed Valve
Hybrid Front Mount Intercooler
HKS GT2535
Apexi Power FC
Standard Injectors
Standard AFM
Standard Internals
Car made 240.6 RWKW on 15psi Now im after some bigger injectors a Z32 AFM up the boost and more power :happy: But all in good time.
Edited by iLEC
