R33 series 2 (96)
3" turbo back
fmic 600*300*76mm
high flow'd fuel pump
stock turbo (as mentioned before it has steel compressor wheel????)
Profec b boost controller
175rwkw @ 8-9 psi and 200rwkw @ 12-10 psi (boost drop) and running very rich!
I would like to here any thoughts anyone may have on this dyno run.
Cheers.
got my car tuned today it made 243hp at the wheels or 181rwkw on 11.2 psi
stock turbo
600x300x76 fmic
3inch dump 3.5inch cat back with stock cat
apexi safc series 1
this is a little on the low side i think concidering every one else with stock turbo is making around 200kw do you think its the stock cat or the safc???
97 r33gts-t 209kw/280hp atw (w/dyno sheet)
stock turbo @13.5 psi
stock ecu with SAFC2
3" split dump pipe + full 3"exhaust (still stock cat 4 now)
hybrid fmic
pod with heatshield
turbosmart dual stage boost controller
BP Ultimate fuel
RB25DET Series 1
GT30R turbo
tial 38mm gate
generic stainless steel manifold
PFC + Z32 AFM
600x300x75mm cooler
3" exhaust
740cc nismo injectors
040 bosch pump
k&n pod
blitz spec r ebc
BP Ultimate
324rwhp
about 11psi.
id like to think 350rwhp on a constant 1bar is possible.
Edited by _8OO5TED_
1996 R33 Series 2
Stock Turbo at 11psi(GFB bleed valve)
Apex PowerFc
Z32 AFM
Walbro Fuel Pump
Full turbo back exhaust
K&N Pod
Hybrid FMIC
BP Ultimate
Made 253.7 HP in non shootout mode with safe tune for daily driving. Made more power with turbo at 13.5psi but decided to ease back.
R33 Gtst S1
Results as per my signature... currently 226.5RWKW (will scan dyno sheets in tonight)
More goodies being installed currently with ECU to be installed next week:
555 Injectors
External fuel pump
FPR
ECU (Adaptronic)
Custom Plenum
Metal Headgasket
Cam Gear
Cam Shafts
New hoses throughout engine just incase lol...
GT3540 for when Stage 3 highflow is max'd out
And then..... wait for stock internals to crap themselves before installing a RB30 bottem end :) (Dad won't help me build the bottom end whilst there is a perfectly good one still working in the car :dry: )
Now sitting at 262.3 rwkw on 16psi.. We made 279rwkw on 18 psi but it the highflow was being maxed... dropped it back to 16psi to be a bit nicer the the turbo :banana:
Added the Adaptronic, injectors, fpr, plenum (although awaiting another :) ), cam gear + fuel pump!
Tuned to run really rich due to the plenum leaning out no3 with the airflow. New greddy plenum and Garrett to be installed in two weeks.. will update then when the afrs are a little more friendly to my fuel economy!
1995 R33 Skyline - Series 1.5
Hybrid front mount
Power FC
Walbro fuel pump
Gt3071 interal gate with ground out R33 rear housing
Splitfire coilpacks
3" turbo back exhaust
Greddy profec spec 2 boost controller
Custom intake with pod filter
Stock afm
Stock injectors
Stock plenum
Stock exhaust manifold (except for a bit of porting done by myself)
Pretty safe tune by Mercury Motorsport
Made 234kw atw at 15psi on BP Ultimate
Full boost was seen at 3200rpm with no boost drop off at 7000rpm :wub:
Edited by SmittyR33
PFC shat itself so after getting that fixed and retune the updated dyno sheet is posted.
Performance specific mods ate
Nismo fuel pump
Full exhaust
Custom Garrett turbo
z32 AFM
Blitz FMIC
AVC-R
Power FC
Hard intake pipe
Radiator upgrade
Stock internals
Stock injectors
Stock cams
Next on list:
Injectors
Splitfires
FPR
and then a rebuild.
I had my car dyno today.
I have a 96 GTS-T SII.
Mods so far
A POD
Turbosmart BC Duel
Split dump pipe
Exhaust with a 2" cats and 3" tips.
FMIC
My computer is a Apexi Power FC with HC
Tuned by CRD
12PSI producing 193RWKW
Next group of mods will be
Upgraded Turbo..maybe a hi-flow turbo
Fuel pump
Fuel Reg
Air flow meter
RB25DET
Tomei 256 8.5mm cams
HKS 3037S ex 0.74 56T
Turbosmart 48mm pro gate.
FMIC
3 inch exhaust Catco cat.
550cc injectors.
standard water/oil pump.
Autronic SM2 with 500R CDI
Autronic boost controller
Low boost 16psi 370rwhp
high boost 19psi 400rwhp
Check out the torque curve.....I mean flat line :P
R33 series 1 (95)
Rebuilt engine (forged internals)
Gt3540 .84a/r
Tomei poncams 256
Hks EVC
hks intercooler
twin DIS-4 ignition system
Link g2 ecu
~300wkw @ 14 psi and 325rwkw @ 17 psi
Healthy amoount at this stage but I expect more should come once we finetune the maps later !! :D
1995 R33 GTS-T
std internals
n1 water pump
HKS stage 1 inlet cam
HKS stage 2 exh cam
HKS adj cam gears
HKS timing belt
HKS air filter kit
nismo FPR
Plazmaman plenum
sard 550cc injectors
walbro fuel pump
custom GT3076 ext gate turbo with 0.63ar exh hsg (i would recommend 0.86 for RB25)
TiAL 38mm W/G
s/steel hi mt exh manifold (brand unknown)
GTR front mount custom piping
apexi AVCR (would use HKS controller if i was to choose again)
apexi PFC
It made 259.8rwkw at 7000rpm but has very stong midrange but lower tourque and power tapered off in the top. I will try and get a 0.86 hsg and re-dyno and see what the difference is. But as the package stands it is fun to drive and the boost is only set at 1 bar, so with bigger hsg and 1.1 maybe 1.2 bar it should make 270 kw with more tourque.
This in what i have in my 1991 gtst
Current Mods are:
S2 RB25det engine
RB20det gearbox with a rb30 H/D clutch
3" custom dump/front pipe with a 3" Tanabe catback exhaust
K&N Pod Filter
Walbro 500hp fuel pump
managed to get 211.3rwkws @ 6284 rpm with 1425mn torque (331mn at the flywheel). Only ran 9.33psi of boost
Dyno sheet
Edited by Nishant
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
    • Toasty! I was around the same. Around 50 but with a fuel cooler. Got my tuner to dial down the pumps and its so much better.. i think last time I drove it was around 35-40 during summer. PWM makes a huge diff. I have the 1 PWM controller running my feeds.
