R33 GTSt 93 model
Apexi pod & box
z32 AFM
slide hi-flow turbo
FMIC
Nismo 555cc injectors
Greddy Profec II boost controller
Apexi powerFC
3 inch front and dump pipe
3 inch hi-flow cat
3 inch Nismo cat back
235.8rwkw @ 15psi - all work done by Unigroup :nyaanyaa:
Turbos Australia HiFlow
Front Mount
Walbro
3" turbo back
Power FC
Nismo Fuel Reg
Copper plugs
Stock injectors
HitMan tune
228.5rwkws
pic of the SAFC II tune compared to Power FC tune
GT3071R from GCG with one of their T3 rear housings (op6 casting) .7 ar
FMIC
Bosch Motorsport pump
AM Performance split dump with screamer, 4 inch pipe with duel 3 inch mufflers
Malpassi Rising rate fuel press reg
stock injectors
RB20 ECU remapped by The Speed Lab
20 psi boost due to overboosting
this is the result - 283 rwkw
1997 R33 GTS-T
FMIC
3" Catback
POD
*Everything else stock
Fuel pump wasnt making pressure so dyno didnt go all the way..
Added:
Tomei Fuel Pump
3" JJR Split Front/Dump
Blitz Spec-R DSBC @ 12psi
SAFC-Neo
Tomei 1.5 mm metal headgasket.
Apexi Power Intake
Z32 Air Fuel Meter
Big FMIC with hard pipe kit
Nismo 555cc Injectors
Walbro 255lph fuel pump
Painted Rocker Covers
Greddy Profec B Spec II
Apexi Power FC & Hand Commander
boost = 0.6 off, 0.9 low, 1.3 high
Turbocharger
HKS GT3037 Pro S Turbo Full Kit
HKS Turbo Elbow
Exhaust:
HKS Front Pipe
Kakimoto Full Exhaust
Drivetrain:
OS Giken Twin Plate clutch and flywheel
437bhp @ Flywheel with 410lb ft @ 1.2bar
367bhp@ Flywheel with 325lb ft @ 0.8bar
Here is the dyno graph. This one shows at the wheels power and boost pressure.
You can see the HKS spools up pretty quick and on the road it feels better than the standard turbo!
Its strange as its hitting full power boost has dropped down to about 1.15. Wonder if it help 1.3 all the way what kind of power it would be then.
Edited by Paul GTS
1995 R33 GTS-T
3'' Turbo Back Exhaust
3'' High flow cat
Cooling Pro FMIC
HKS Spounge Air Filter
No boost control (currently boosting at 8 pounds)
Dyno just after the work was done at 215rwkw
'96 RB25DET Skyline
ATP Stage 3 Hi flow turbo.
Apexi 3" Turbo back exhaust
Apexi power intake
Z32 AFM
Koyo aluminium 100mm radiator.
Greddy oil cooler and filter relocation kit
GREDDY FMIC
Power FC w/ boost control set @ 1.1 bar (16psi)
249.7rw/kw @ RE Customs
Link ECU
600cc Injectors
040 pump
arc intercooler
5zigen exhaust
custom built SONIC PERFORMANCE GT3584R-IW
Internally gated GT35 - ported flapper, T04z 66mm comp wheel, XR6 comp housing low mounted on factory manifold
16psi
374HP @ Wheels - 280KW @ Wheels
RB25DET engine internally standard :P
Edited by GT3584R
mostly stock rb25det auto
3" turbo back exhaust
Pod filter
FMIC
stock boost 6psi, stock r33 fuel pump & stock r33 ECU.
200.3 rwhp untuned (the .3 makes me feel better)
new parts waiting to be added and new tuned dyno run to come.
r34 gt-t
this when it was on auto...
standard NEO 6 RB25DET motor
gt35r 1.06 rear on standard manifold..adapter made up to suit
38mm ultragate
bosch 040 fuel pump
APexi SAFC2
Apexi AVC-R
standard injectors
pushed out 227rwkw
ill give and update soon when i get my car tuned with the manual conversion and ohther bits added
1997 S2 R33 Skyline
Blitz POD
Blitz FMIC
Gizzmo EBC
3 inch turbo back exhaust
Hi flow cat
11psi
standard computer pump etc
188rwkw
Edited by RB25DETS2
FULL INTERNALLY STANDARD MOTOR, HEAD TO SUMP
high flowed 720cc injectors (Creatd Motorsports)
Greddy plenum
Tomei 500hp fuel pump
r32 gtr intercooler
GT35R .63 turbo
apexi air filter
stainless exhaust manifold from Slide performance, Modified by Creatd Motorsports
Tial 44mm wastegate
apexi power fc
z32 afm
full straight thru 3" exhaust
greddy profec b spec II ebc
295KW on 18psi boost with 98 octane pump fuel.. :P
BIG thanks to Creatd Motorsports for helping me out with this build.. A Grade work and the Tune is perfect! car wouldnt be the way it is without Rob Gas and Daniel!
Edited by LTHLRB
R33 S1 1995 :
Z32 AFM
Power FC
Power FC BKC
Stock Turbo
12 psi
Apexi Power intake pod
3 inch front dump pipe into stock NA cat then to a 3 inch cat back
Front Mount Intercooler
walbro 500 hp fuel pump
and i got 256.2 hp
so is how many KW's is that?
Cheers
Chi
Edited by Chi100188
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
