1999 R34 GTT - RB25det Neo
Auto - Stage 2 shift kit
3" turbo back exhaust
Hi-flow cat
Silicon intake pipe with apexi filter
Greddy FMIC
Greddy profec B spec II
Walbro 255lph fuel pump
Nistune Type 4 Board
Standard turbo, Injectors, AFM
259.4rwhp(~194rwkw) @ 12psi
RB25 NEO
Engine internals standard
GT3076R with ATP 0.78 T3 split rear housing
6boost split manifold
tial 44mm wastegate with 22psi spring (no boost controller)
3.5" exhaust
Greddy Intake manifold
Q45 TB
Z32 AFM
sard 800cc injectors
Bosch 023 pump
stock coils
V-power 8s gapped at 0.8mm
Nistune
399RWHP @ 6800rpm
More tuning left to do...
R34 GT-T
RB25DET Neo
Fujitsubo Turbo back exhaust
Apexi Pod Filter
i think stock boost 7-8psi, was a dyno day so dyno operator didnt get time to get boost reading.
Standard ecu, turbo, smic
BP Ultimate
167.1rwkw
Found out it only has a cat back exhaust and a stock dump pipe, hence the lowish power for the mods. Was on about 8.5psi.
Update!
Trust Turnflow Intercooler
Boost upped to 10psi via turbotech boost tee
Nistune tuned by Sam (Dr Drift)
190rwkw @ 10psi
97 S2 R33 gtst
Trust fmic
Tpiece set to 10psi
Jasma catback exhuast
Pod filter
Standard turbo
228 rwhp (was at last powercruise and since have heard dyno ran low numbers but i dont know for sure)
series 2 R33
stock engine
stock cams
Power FC
850cc sards
Z32 afm
Trust EBC
hybrid cooler
3 inch exhaust
GT3582 .8 internal gate
high mount ETM manifold
running E85 :blink:
3.5 inch catback
couple more psi
ACL metal head gasket
Rear housing size: 1.06
Wastegate size: Turbosmart 50mm
Boost Level: 22 psi
Gearbox: 3 speed C4 4000 stall transbrake
Diff Ratio/LSD: 4.11 LSD
1/4 mile time: n/a
Engine Internal Mods:Built RB25DET
Extra info: E85fuel
Power: 335rwkW on Unigroup dyno
rb25det unopened
stock exhaust manifold
z32 afm
nisstune rb20 ecu
eboost
fmic
3inch turbo back no mid mufflers or cat.
740cc hiflow stock injectors
gt3076r .82
turbosmart ultragate 38mm external wastegate
300.7rwkw @15.8psi
full boost hits at 4200rpm
all in a r32 :D
1998 R34 GTT
RB25DET NEO
Stock Turbo
Stock Injectors
Stock Fuel Pump
Blitz Return-Flow FMIC
Greddy Profec II Boost controller on 11psi
K&N panel inside stock airbox
Xforce 3" Turbo back exhaust, with high flow cat
0.8 Gapped Plugs
NIStune type 4 daughterboard
214.6rwkw
Built RB25 stock head/cams
AFI tubular manifold (divided)
Divided 3076R 1.06 T4 housing
850cc injectors
freddy intake manifold
haltech ems
full 3 inch exhuast
twin tial mvs 38mm wastegates (reciculated)
20psi
400whp 376wtq
wanting more power seems like something is holder her back??
r32 rb25det s2
unopened
stock ecu
stock turbo
front mount
3 inch turbo back exhaust
hi/low boost controller
on low boost 7psi made 160.9kw atw afr was 10.5
hi boost 10psi made 185.9 kw atw afr was still abit rich could do with a bit more boost
dyno'd at dr drift :O
1989 r32 with rb25
Gt3582r .86 rear housing with anti surge drilled front housing
Forged pistons
shot peened rods
balanced and nitraded crack
stock cams
exhaust cam gear
head port matched to manifolds
custom plenum with 83mm sub zero throttle body
high mount ""ebay" manifold- modified
50mm wastegate
Microtech lt8s with update program and 40psi external MAP sensor
Mircotech X6 ignition module
6x bosch coils with top gun leads
highflow factory side feed injectors
walbro in tank fuel pump
BP ultimate 98
446hp on 18psi and 351kws or 471hp on 23psi.
upgrading injectors before 25psi run
Edited by nick81xd
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
