Car Info
1999 Nissan R34 Skyline 'GTS-R'
ARC Super induction Box
Z32 AFM
HKS T04S turbo (small and vintage spec turbo) .63 rear
HKS cast iron low mount manifold
HKS 38mm street spec external gate
HKS dump/front pipe
HKS Super dragger cat back exhaust
Magnaflow stainless steel hi-flow cat
Hybrid HDi GT Spec intercooler and piping
Splitfire coil packs
Bosch 023 fuel pump
Standard injectors
Standard Fuel Pressure Reg
HKS oil cap and HKS radiator cap (yep... made a world of difference)
Nistune ECU
330rwhp or 242rwkw at 17psi
VC Commodore with Neo RB25DET conversion
Plazmaman inlet manifold
ARE custom intercooler
VIPEC Plug n Play Computer
NISMO 740cc injectors
Mercury Motorsport fuel system
Garrett GT4508R Turbo
6Boost manifold
STANDARD ENGINE + ARP HEAD STUDS + NITTO HEAD GASKET
3.5" exhaust by Mercury Motorsport
NPC Twin Plate Clutch
RB25 gearbox
9" Diff etc
POWER: 587rwhp on 25psi (E85)
Car is currently getting a ZEX nos kit fitted and a few other goodies......
Howdy,
Just had my R32 w series II RB25 tuned by Dr Drift.
Mods as follows:
- Nistune & Z32 ECU
- 3'" Exhaust
- Blitz turnflow FMIC
- Pod
- HKS 2530
- Yellow Jacket Coil Packs
- Boost T
- Z32 AFM
Car makes full boost by about ~2,700 RPM and pulls like a train!
Made 218 rwkw on a very conservative tune and only 14 pound
The Doctor does very good work!
Cheers,
Garrett GT3076R with .82a/r internal wastegate, Garrett 1bar big can actuator, Apexi AVC-R + Norgren Pressure relief valve, Trust PE2 Exhaust, GTSLink ECU, Walbro Fuel Pump, Nismo 555cc injectors, complete stock internals/manifolds, Chinese intercooler
301rwkw at 17psi:
Don't have my old dyno sheet handy but...
R34 - RB25DET NEO
Previous:
Custom FMIC
Apexi POD
Profec B
3" Turbo back exhaust
Everything else standard
185kw @ 13.5psi
The car went into the shop yesterday for:
GT3076 IW .82 rear
800cc injectors
Haltech P2000 ECU (Map sensor)
Bosch fuel pump
Hoping for:
250(ish) @ 15psi and
300+ @ 20psi
Will post results and dyno sheets when i get the car back next week.
Hi there from the UK
Here's my first run ever ...
1998 GTSTS2
Standard exhaust
Standard intake system
R34 FMIC
HKS EVC3
Standard Turbo @ 1bar (14 psi) :(
Standard low octane fuel.
300HP 224KW at clutch
248HP 189KW at rear wheels
Edited by Torques
unopened Neo Rb25det
-3076 56t with .64 housing
-highmount AM Performance stainless steampipe manifold with HKS 38mm gate
-Profec Spec B
-600cc injectiors
-fmic
-3.5 inch exh
-Nistune
310 rwkw @17 psi at around 6800 rpm
fullboost by 3500
roughly 480 nm torque at engine (calculated)
got Poncams type B's coming very soon. its a drift car so want more midrange torque. makes plenty peak power. Was thinking i might swap the rear housing to a .82 with pon cams tho... see how i go.
Got the car back yesterday from its final tune..
Stock turbo
Stock AFM
Stock injectors
Splitfire coils
JJR fmic
JJR Split dp
Custom 3' system
boost set at 12psi, tapers off to just over 10 at redline.
222.6rwkw
Tuned by Mark at MRC
Car:R33-1996-manual
Power FC
Frontmount
Greddy style plenum
Podfilter with CAI
3 inch turbo back exhaust
Tomei fuel reg
Apexi-AX53b70 turbo
Stock injectors
Walbro fuel pump
Stock AFM
299.2 rwhp on DynoDynamics at PITS
Had my car dyno'd today at CRD.
Specs:
Rb25det with stock internals
550cc nismo injectors
Bosch 040 fuel pump
Nismo Fuel Pressure Regular
Hybrid? FMIC
Rebuilt VL turbo with Garret 3071 turbine
Greddy Profec B spec 2 boost controller
Old Tuned PFC(In desperate need of a tune
Shitty pod filter
Made 225rwkw on 14psi and 5200n torque.
Cant edit my above post?
Edited by R31Nismoid
'95 SII R33 GTS-T
FMIC
Forward facing plenum
Bosch 044 fuel pump
ITS turbo
External gate
3" Zorst no cat
PFC
740cc injectors
Z32 AFM
Pod filter
BP Ultimate
1 BAR boost
316rwhp @ Allstar Garage
yet to be tuned with new turbs
Garrrett GT30/76
Custom Stainless High mount manifold.
Edited by stR33ter
99 R34 GTT - RB25DET NEO
Custom FMIC
Apexi pod filter
Custom cold air intake / induction
Garrett GT3076 internal gate .82 rear
700cc (ish) high flowed standard injectors
Haltech P2000 ECU (3 bar map sensor)
Bosch fuel pump (?)
Greddy Profec spec B boost controller
Daily driver 'safe tune' @ 18psi = 272.9rwkw
Max power before 6k all the way to redline so definitely has more in it!
Tuned by Simon @ Morpowa.
here's my 89 R32
-flashed over ECU with an Omoni Tune with no restrictors
-1.2 bar
-pump fuel
- RB25 conversion, Apexi 400hp turbo, HKS FMIC, Walbro fuel pump, Splitfire coilpacks, Greddy radiator, shimmed diff.
hit 306rwhp
R33 GTST '96
Stock internal RB25
Nistune
Apexi AX53B70 (P25)
S15 injectors (450cc)
HDi FMIC
Z32 AFM
Full 3" into 2 x 2.5" exhaust
227rwkw
RPM in graph is about 5% too low - full boost at 3500rpm.
3 tunes at increasing boost - still not maxed out (but not too much left, maybe 1psi).
Edited by simpletool
Series 2 R33 96
Mod List are:
Stock RB25DET Engine
Hi Flow Turbo (2860RS) Spec 0.86A/R made by HyperGear ;-)
3" Turbo Back Exhaust.. Punched out Hi-Flow Cat
SplitFires Coilpacks
HKS EVC V Boost Controller
Hybrid FMIC
Cold Air Intake with Partition
Apexi Pod Filter with Hard Intake Pipe
Bosch 910 Fuel Pump
Sard 550cc Injectors
Z32 AFM
Power FC
BP Ultimate 98
Hits 14PSI by 3750rpm
Tuned @ 16PSI by Steve Thomas @ Performance Unlimited WA
Made 318.3RWHP or 238Rwkw on a Roller Dyno
Edited by Black_CSR
1998 Series2 40th Anniversary Skyline
335 RWKW
gt35 .63 rear
Vi pec ECU
725cc Injector Dynamics
22psi
Bp[ultimate
tomei pon cams
will put up new dyno graph once i fit new 272 cams and cam gears and more boost and when i can figure out how to upload pics onto website having troubles im a dummy when it comes to computers.
Edited by UW8NCY
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
