R33 Series 1.5 5spd manual
Stock RB25det series 2 engine
-3" turbo back mandrel bend exhaust
-Hypergear Hiflow 21U housing (not sure on turbo spec)
-Stock inlet exhaust manifolds
-Z32 afm
-Pod filter
-Stock injectors
-Frount mount intercooler
-Bosch 044 fuel pump
-Remaped Ecu (By Toshi on here)
-Exeddy Gtr 5puk cermaic clutch with chromolly flywheel
Makes 260.3rwkw on 15psi
1995 R33 Series 1 RB25DE motor
Engine
Nissan N1 Oil & water Pumps
Nitto Crank collar to suit N1 oil pump
New Low temp Thermostat
Nitto 1.2mm head gasket
ACL Race bearings
Nitto Forged Pistons
Nitto forged H-beam rods
Machine Head & Block
Linish crank
Bore and Hone
Nismo 740cc injectors
Management
Haltech Plug in Pro ECU
Turbo
Garret 3076R
AzCustom high mount manifold
44m Tial Wastegate
311kw @ 21psi
Running on BP Ultimate
Build Thread http://www.skylinesaustralia.com/forums/topic/352798-zoids-gts-build/
YouTube Dyno Video
Edited by zoidbergmerc
Just had my car re-tuned at EFI performance today after putting heavy duty actuator on:
Power FC
Apexi AX53B70 p25 turbo
Stock air box
Walbro fuel pump
Tomei adjustable fuel reg
Vulture motorsports plenum
Front mount IC
Apexi 3.5 inch exhaust
Stock injectors
Stock air flow meter
the ol neo.
HKS 2835 kai
nismo 480cc injectors
nistune
+ the usual stuff
tuned at 14psi. exhaust is causing a restriction
retuned with a new zaust.
320hp @ ~16psi
disappointed with the figure, feels significantly better however.
hopefully 89cal will have some good news for me soon.
Here's Mine:
Sorry, here it is..
186.7rwKW
545Nm
Stock turbo, 12psi
Disappointing power figure but very different and nice feel on street, very happy with physical result, but power drops off after 5000-5500rpms - as seen by the chart, can feel it on the street just as the chart indicates, lack of turbo ooomph after 5500rpms, that power result on chart was achieved at 14psi though, quite a disappointing number - was told my stock dump could be the cause. But then again it feels way faster and better to drive than the numbers indicate - fuel economy hasnt improved much though 15+L/100kms - but I do a lot of short distance stop-start driving and quite a few redlining as well..:cool:
R33 GTS-T S1
213rwKW @13 psi
13.1 @ 109mph
Highflow Turbo ( Unknown )
740 cc injectors
Malpassi Fuel Reg
Bosch 044 Fuel pump
Surge pump
3 " Exhaust
High performance Cat
Z32 AFM
Apexi pFC
HDI Boost Controller
Yellow jacket Coil packs
Intercooler
I think i should be getting a better Dyno result with the supporting mods... Anyone think differently ?
Got my car tuned but its going back soon.
Anyway its an R33 GTST Series 2 with the following:
Unopened RB25DET
HyperGear ATR43SS-2
3" JJR Bellmouth dump
HKS Hi Power Silent exhaust
Yellow jacket coils
NGK Copper plugs BCP7RES gapped to .7
Genuine HDI FMIC
Venom 5" body 100cpsi cat
Bosch 040(was failing during tune)
Nismo FPR
Greddy profec b spec 2
3" metal intake with Apexi power intake filter
Power FC tuned by Advan performance
Made 244rwkw on 11.4psi. That is with the boost controller set to 100%. That is as much as we can get out of it. With about 15psi, we should see about 270rwkw and 17psi about 280rwkw. 20psi should see 300rwkw on regular fuel pump.
Ive fitted a GTR fuel pump in there to fix the fuel pump issues. Probably will swap that with a brand new 040 pump or run it as a lift into a surge tank. Last printed dyno shows about 238rwkw on 11psi, should have printed the previous runs :P
R34 GTT
Unopened RB25DET NEO
HKS GT2835 KAI
Z32
850CC power ent. injec.
Nismo Fuel Pump
FMIC
Power FC
Blizt BC
Splitfires
some 3" zorst
350hp/261kw @ around 17psi
little rough on cruise so will take it back to tidy the tune up but not expecting any extra power.
93 R33 GTST Rb25det with forged pistons (factory compression) and stock every thing else.
550cc injectors
Z32 AFM
HyperGear ATR43SSxx Work in progress Prototype turbocharger
3inch turbo back exhaust
Ebay cooler
Nistune chipped ecu
264.2rwkws at 22psi. Full boost by 2900rpms. Super responsive.
Below is based on 9 second dyno ramp.
hey guys, old dyno results with the 25 will post up new results after it goes in for a tune
R33 GTS-T S1,
S2RB25DET
Stock S2 Turbo
Mines ECU
Stock Internals
FMIC
3" turbo back exhaust
Pod Filter
Making 207.3rwkw @12psi & 228rwkw @15psi
Edited by Autumn33
Hi all,
R33 GTS-T S2, RB25
Stock Turbo
Stock ECU
Stock Internals
Stock motor
FMIC
Custom dump into 3" turbo back exhaust
Pod Filter
Running 187.9rwkw @ 9psi
with BP Ultimate.
Just got the car back from Croydon Racing Development
Nistune
HKS 550CC Injectors
Bosch Z32 AFM
Walbro Fuel Pump
Boost was set to 16psi (i think a bit too much for the standard turbo.. lol)
Ran 229.7rwkw
550cc injectors
Z32 AFM
HyperGear ATR43SS-1PU turbocharger
Ebay cooler
Nistune chipped ecu
Here's update with the SS1 PU prototype.
291rwkws@21psi (run was not complete as cooler pipe slipped) when the cooler is cold and average of 270rwkws@21psi when the cooler is hot, 260rwkws@14psi.
Runs were done on 14psi (red) and 24psi (yellow/Blue) high pressure actuators. No boost controller was used on those runs. This turbo was not equipped with a gate controller.
9 sec ramp:
1996 R33 S2 GTS-T M-SPEC II
Stock internals (except for 256 in/ex poncams and adjustable exhaust gear)
Stock Turbo/wastegate/manifold
3" Turbo back exhaust with a 3" into 5"body out 3" 100CPSI vemon cat.
Apexi POD Filter
Tomei FPR (large)
Intercooler
Spitfire Coilovers
NGK platinum tipped spark plugs gapped at 0.7t
Apexi AVC-Type R
GFB Aftermarket BOV (to confirm for anyone, NO boost leaks have EVER occured whilst using this aftermarket BOV)
208rwkw on low Boost - 7psi
214.7 on high Boost - 14psi
That was the most we could squeeze out as the actuator was being restricted and the air mass meter had reached it's limits. Upgrades to come in near future :D.
Edited by Reflector
R34 GT-T
RB25DET Neo
JJR 1 piece dump pipe, Venom 5" body cat, 3" inlet, 3.5" outlet, 3.5" catback straight through
Apexi Pod Filter with 3" metal intake
Z32 AFM, Nistune ECU, 800cc Deatschwerk injectors
ARC Returnflow Intercooler
Hypergear ATR43-SS1
244rwkw on 98, and 279rwkw on Caltex E-Flex E85!
Super responsive!
Series 2 R33 GTSt, RB25DET, 188.89 rwkw or 253.3 rwhp.
Stock motor at 170,000 k's.
Stock turbo at 14 psi
900cc JECS injectors
Z32 afm
walbro 341
600x300x100 front mount
Power fc
Pod filter
HKS split dump
3inch front pipe, stock cat, 3 inch kakemoto catback.
BP 98
Tuned by me and checked by Rotomotion.
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
