R33 Series 1.5 5spd manual
Stock RB25det series 2 engine
-3" turbo back mandrel bend exhaust
-Hypergear Hiflow 21U housing (not sure on turbo spec)
-Stock inlet exhaust manifolds
-Z32 afm
-Pod filter
-Stock injectors
-Frount mount intercooler
-Bosch 044 fuel pump
-Remaped Ecu (By Toshi on here)
-Exeddy Gtr 5puk cermaic clutch with chromolly flywheel
Makes 260.3rwkw on 15psi
1995 R33 Series 1 RB25DE motor
Engine
Nissan N1 Oil & water Pumps
Nitto Crank collar to suit N1 oil pump
New Low temp Thermostat
Nitto 1.2mm head gasket
ACL Race bearings
Nitto Forged Pistons
Nitto forged H-beam rods
Machine Head & Block
Linish crank
Bore and Hone
Nismo 740cc injectors
Management
Haltech Plug in Pro ECU
Turbo
Garret 3076R
AzCustom high mount manifold
44m Tial Wastegate
311kw @ 21psi
Running on BP Ultimate
Build Thread http://www.skylinesaustralia.com/forums/topic/352798-zoids-gts-build/
YouTube Dyno Video
Edited by zoidbergmerc
Just had my car re-tuned at EFI performance today after putting heavy duty actuator on:
Power FC
Apexi AX53B70 p25 turbo
Stock air box
Walbro fuel pump
Tomei adjustable fuel reg
Vulture motorsports plenum
Front mount IC
Apexi 3.5 inch exhaust
Stock injectors
Stock air flow meter
the ol neo.
HKS 2835 kai
nismo 480cc injectors
nistune
+ the usual stuff
tuned at 14psi. exhaust is causing a restriction
retuned with a new zaust.
320hp @ ~16psi
disappointed with the figure, feels significantly better however.
hopefully 89cal will have some good news for me soon.
Here's Mine:
Sorry, here it is..
186.7rwKW
545Nm
Stock turbo, 12psi
Disappointing power figure but very different and nice feel on street, very happy with physical result, but power drops off after 5000-5500rpms - as seen by the chart, can feel it on the street just as the chart indicates, lack of turbo ooomph after 5500rpms, that power result on chart was achieved at 14psi though, quite a disappointing number - was told my stock dump could be the cause. But then again it feels way faster and better to drive than the numbers indicate - fuel economy hasnt improved much though 15+L/100kms - but I do a lot of short distance stop-start driving and quite a few redlining as well..:cool:
R33 GTS-T S1
213rwKW @13 psi
13.1 @ 109mph
Highflow Turbo ( Unknown )
740 cc injectors
Malpassi Fuel Reg
Bosch 044 Fuel pump
Surge pump
3 " Exhaust
High performance Cat
Z32 AFM
Apexi pFC
HDI Boost Controller
Yellow jacket Coil packs
Intercooler
I think i should be getting a better Dyno result with the supporting mods... Anyone think differently ?
Got my car tuned but its going back soon.
Anyway its an R33 GTST Series 2 with the following:
Unopened RB25DET
HyperGear ATR43SS-2
3" JJR Bellmouth dump
HKS Hi Power Silent exhaust
Yellow jacket coils
NGK Copper plugs BCP7RES gapped to .7
Genuine HDI FMIC
Venom 5" body 100cpsi cat
Bosch 040(was failing during tune)
Nismo FPR
Greddy profec b spec 2
3" metal intake with Apexi power intake filter
Power FC tuned by Advan performance
Made 244rwkw on 11.4psi. That is with the boost controller set to 100%. That is as much as we can get out of it. With about 15psi, we should see about 270rwkw and 17psi about 280rwkw. 20psi should see 300rwkw on regular fuel pump.
Ive fitted a GTR fuel pump in there to fix the fuel pump issues. Probably will swap that with a brand new 040 pump or run it as a lift into a surge tank. Last printed dyno shows about 238rwkw on 11psi, should have printed the previous runs :P
R34 GTT
Unopened RB25DET NEO
HKS GT2835 KAI
Z32
850CC power ent. injec.
Nismo Fuel Pump
FMIC
Power FC
Blizt BC
Splitfires
some 3" zorst
350hp/261kw @ around 17psi
little rough on cruise so will take it back to tidy the tune up but not expecting any extra power.
93 R33 GTST Rb25det with forged pistons (factory compression) and stock every thing else.
550cc injectors
Z32 AFM
HyperGear ATR43SSxx Work in progress Prototype turbocharger
3inch turbo back exhaust
Ebay cooler
Nistune chipped ecu
264.2rwkws at 22psi. Full boost by 2900rpms. Super responsive.
Below is based on 9 second dyno ramp.
hey guys, old dyno results with the 25 will post up new results after it goes in for a tune
R33 GTS-T S1,
S2RB25DET
Stock S2 Turbo
Mines ECU
Stock Internals
FMIC
3" turbo back exhaust
Pod Filter
Making 207.3rwkw @12psi & 228rwkw @15psi
Edited by Autumn33
Hi all,
R33 GTS-T S2, RB25
Stock Turbo
Stock ECU
Stock Internals
Stock motor
FMIC
Custom dump into 3" turbo back exhaust
Pod Filter
Running 187.9rwkw @ 9psi
with BP Ultimate.
Just got the car back from Croydon Racing Development
Nistune
HKS 550CC Injectors
Bosch Z32 AFM
Walbro Fuel Pump
Boost was set to 16psi (i think a bit too much for the standard turbo.. lol)
Ran 229.7rwkw
550cc injectors
Z32 AFM
HyperGear ATR43SS-1PU turbocharger
Ebay cooler
Nistune chipped ecu
Here's update with the SS1 PU prototype.
291rwkws@21psi (run was not complete as cooler pipe slipped) when the cooler is cold and average of 270rwkws@21psi when the cooler is hot, 260rwkws@14psi.
Runs were done on 14psi (red) and 24psi (yellow/Blue) high pressure actuators. No boost controller was used on those runs. This turbo was not equipped with a gate controller.
9 sec ramp:
1996 R33 S2 GTS-T M-SPEC II
Stock internals (except for 256 in/ex poncams and adjustable exhaust gear)
Stock Turbo/wastegate/manifold
3" Turbo back exhaust with a 3" into 5"body out 3" 100CPSI vemon cat.
Apexi POD Filter
Tomei FPR (large)
Intercooler
Spitfire Coilovers
NGK platinum tipped spark plugs gapped at 0.7t
Apexi AVC-Type R
GFB Aftermarket BOV (to confirm for anyone, NO boost leaks have EVER occured whilst using this aftermarket BOV)
208rwkw on low Boost - 7psi
214.7 on high Boost - 14psi
That was the most we could squeeze out as the actuator was being restricted and the air mass meter had reached it's limits. Upgrades to come in near future :D.
Edited by Reflector
R34 GT-T
RB25DET Neo
JJR 1 piece dump pipe, Venom 5" body cat, 3" inlet, 3.5" outlet, 3.5" catback straight through
Apexi Pod Filter with 3" metal intake
Z32 AFM, Nistune ECU, 800cc Deatschwerk injectors
ARC Returnflow Intercooler
Hypergear ATR43-SS1
244rwkw on 98, and 279rwkw on Caltex E-Flex E85!
Super responsive!
Series 2 R33 GTSt, RB25DET, 188.89 rwkw or 253.3 rwhp.
Stock motor at 170,000 k's.
Stock turbo at 14 psi
900cc JECS injectors
Z32 afm
walbro 341
600x300x100 front mount
Power fc
Pod filter
HKS split dump
3inch front pipe, stock cat, 3 inch kakemoto catback.
BP 98
Tuned by me and checked by Rotomotion.
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
