R33 Skyline
Hypergear turbo
bosh fuel pump
e85
plazmaman plenum
plazmaman intercooler
hks bov
i.d 1000cc injectors
power fc ecu
full zorst sytem
spitfire coil packs
Stock motor
358 Rwkw on 20 psi
Edited by Abe2
R32 RB25DET series 2
Stock engine with 740cc nismo injectors.
Z32 AFM in coole piping, return flow front mount cooler.
Kando dynamics TD06 20G SL2 on ebay highmount manifold turbo smart 35mm gate (too small need 44mm).
BSA Customs 3inch straight through exhaust with hooker muffler.
Tuned on caltex Eflex E70.
Had a missfire and will need splitfire coilpacks and more boost once i have a bigger gate.
Boost was 11psi creeping to 15psi
R33 RB25DET series 2
550cc Deatschwerks injectors.
Bosch 984 Fuel Pump
Z32 AFM
Plazmaman FMIC
GT3076 ATP 0.82 Twinscroll
HKS Cast Manifold Extrude Honed, 50mm HKS Ext Gate
3inch straight through exhaust mid + rear oval mufflers
Venom 100cell Cat
Tuned on Shell V-power 98ron
Boost 22.5psi 4100rpm dropping to 19.5psi 6400rpm
Profec B II
PowerFC
224.6kw, splitfire coil packs, 3.5inch cat back(bashed out cat) plazmaman cooler an intake plenium, srceamer dump pipe, standard turbo 12psi, electronic boost an power fc..looking for turbo upgrade an advice appreciated, wanting 280kw comfortable...
01 ER34
RB25DET NEO
Z32 MAF
BLITZ 525CC I/J
BLITZ I/C
AEROMOTIVE 340 PUMP
HKS GT2535 1.2 BAR
POWER FC
Made 354PS to the wheels, Clutch started to fail anything about 1.2.
Replacing it with a Super Coppermix Twin and trying for a bit more torque and power.
98 R34 GTT
91k KM'S
Z32 AFM
HYBRID FMIC
600CC DEATCHWORKS INJECTORS
HYPERGEAR SS1PU TURBO RUNNING 16 PSI (MAXING AT 17 BUT FADING TO 15) WASTEGATE CONTROLLED
FULL 3" EXHAUST
BOSH 044 IN TANK
STOCK INTERNALS
BP ULTIMATE 98 RON FUEL
340HP - SAFE TUNE
Tuned by RPM Dyno & Performance Morayfield (Peter Roma)
I will put the sheet up on Monday when I go in to work.
Edited by RandomHero83
R33 series 2
splitfires
3" exhaust
3076 52t .63 rear
Tial 44mm gate
adapter to use on stock manifold
nismo 740s
044 in tank
Z32 afn
Z32 ecu and nistune
Tomei poncams
United E85
13.3psi
little bit of wheel spin coming on boost
98 R34 GTT
91k KM'S
Z32 AFM
HYBRID FMIC
FULL 3" EXHAUST
BOSH 044 IN TANK
STOCK INTERNALS
340HP - SAFE TUNE
Tune completed. Results:
R33 S2 coupe factory manual.
Stock engine
Steve Murch Hybrid Turbo
FMIC
Splitfires with NGK Vgroove racing plugs
Apexi pod with CAI
Exedy clutch
HKS T/Timer
Link G4 wtih boost control
Nismo fuel pump, oil filter, thermostat
Tomei dump/front with 3.5 inch exh
Power: 272kw @ 1.2 bar. Backed off due to major boost creep. Detuned to 255kw @ 1 bar.
Will get it retuned with turbo w/g port drilled out and aim for 280kw.
R33 GTS-T S1
(Before build)
Stock motor
Fmic
3.5inch exhaust, HKS super dragger from cat to rear
Nismo 555cc injectors
walbro 255 intank pump
HKS GTRS
stock manifold
z32 afm
Apexi pod in air box
CAI ducting
NGK coppers gapped to 8mm
Power FC + Hand controller
Turbosmart dual port BOV half plumbed back
Oil catch can
Oil cooler.
262.4rwkw @ 20psi , boost control issue spiking to 21psi. PULP 98.
Will scan dyno sheet and edit when i can find the damn thing :)
Lasted almost 2 years at this power level, however.. It recently spun a bearing, soon to come RB28 spool stroker kit and gtx3076r .. currently getting built.
garrett gt3076r low mount turbo
850cc sard injector's
sard rising rate fuel reg
ems 6860 ecu (rigolli tune)
arias forged pistons
walbro fuel pump
hybrid front mount
3in turbo back exhaust
made 234rwkw's on dyno dynamics shoot out mode on 19psi
detuned for rb20 gearbox ( too rich even at 19psi)
93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
550cc injectors
600x300x75mm Front mounted cooler
Xforce 3inch turbo back exhaust
Manual boost controller
ATR43G3 Ceramic roller bearing prototype turbo internally gated
4inch intake pipe
Nistune
Z32 AFM in cooler piping
Pump 98 fuel. Car maxed 302rwkws on 19.6psi
Video:
r32
un opened rb25 s2
greeddy / proboost plenum / factory rb25 tb
power fc/ z32 afm
nismo 555 side feeds
044 pump
gt3582r .82
factory exhaust manifold with 38mm turbonetics waistgate welded on.
good tune
301rwkw on 16psi
Edited by Matthew Black
rb25de+t
standard internals
og trust td06 20g
standard injectors sard fpr
fmic
z32
walbro in tank pump=rubbish pump
hybrid performance staem pipe manifold
tial mvr 44m wastegate
245rwkw@15psi
on bp 98
response monster!!!!!!!!!!!!!!!!!
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
