93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
800cc injectors
600x300x75mm Front mounted cooler
Xforce 3inch turbo back exhaust
Profect B electric boost controller
Brea bolton manifold.
SS2 prototype (290612) Internally gated. 14psi actuator, internally gated.
4inch intake pipe
Adaptronic Plugin
Greedy EBC
Max of 312rwkws on BP 98 and 210rwkws by 4000RPMs
22psi by 3750RPMs, 20psi by 3650 RPMs:
Max of 348rwkws on E85, probably another 15kws in it as my fuel pump is out.
2000 r34 GTt
gt3076 twin scroll .82 rear
twin 40mm gates
6boost mani
plazmaman plenum, throttle body
plazmaman intercooler
044 in tank
1000cc ev14's (standard rail and regulator)
link g4 (controlling boost via MAC solenoid)
3in off turbo into cat to 3.5in pipe to 3.5 hooker aerochamber, gates plumbed back (built by scotty nm35)
running on 98
e85 to come in a couple of weeks
R33 S2 97 Stock motor with,
gt3076 .64
3inch turbo back
power fc
555cc injectors
Tomei Poncam - 256 Degree - 8.5mm
front mount intercooler
bosch 044
Z32 afm
Greddy profec b spec 2
on shell V-power
Running 292rwkw @ 20psi, but drops to 16psi. Once boost problem is fixed should see over 300+
Next upgrades,
740cc or 850cc injectors
Plazmaman plenum
(too get ready for an e85).
Just picked up my new beast
R34 Nissan skyline GTT in black
356rwkw 950nm @ 16psi
- rb25det neo block, bored, honed, decked, soaked and fully cleaned/preped.
Acl 0.5 oversize forged pistons
Carillo forged H-beam conrods
Acl race bearings
Acl frost plugs
Tripple layer steel headgasket
Arp head studs and mains/big ends
new waterpump
Gates racing timing belt and tensioners
recond oil pump
head stripped, cleaned, skimmed, reasembled
- Custom front intake plenum
- 80mm throttle body
- Front mount intercoller,3' piping,
- 50mm Tial bov
- Big aftermarket alloy radiator & electric fan
- Garrett gt35/40 .86 turbo with braided speedflow lines
- Custom Sinco exhaust manifold
- Turbo beanie
- New K&N filter
- 3" hks silent power exhaust with custom downpipe (not overly loud)
- 44mm external wastegate
- 950cc siemens injectors
- Aftermarket fuel rail
- splitfire coils
- surge tank, bosch 044 700hp fuel pump, - fuel pressure reg
- Link G3 ecu
- Gizzmo ibc boost controller
- Blitz turbo timer
Edited by bax_nz
95 SII R33 RB25DET
modified std plenum forward facing
Z32 AFM
FMIC
740cc injectors
Yellow jacket coil packs
6boost high mount exhaust custom 3" dump with external gate and screamer
GT3076 with .86 rear housing
Power FC
Apexi Profec B spec II boost controller
044 Bosch fuel pump
BP98 pump
12 - 14 psi boost
386 rwhp
98 R34 Gtt
Stock turbo
Turbo back 3" 5zigen Exhaust
Custom front mount intercooler,
Goo Fast Bits electronic boost controller.
Made 213.9RWKW on the Tune House Dyno. I will attach dyno sheet when i can find it.
Edited by BeastVS
Hey Guys,
I have been slack lately and didnt post the results, i WILL get Dyno sheets soon but for now -
Car made -
311rwkw on pump 98
320rwkw on E70 at gate pressure of 1 bar
340rwkw on E70 at low boost of 18-16psi
357rwkw on E70 at high boost of 21-18psi
Full boost at 3900ish
The dyno run shows 360.7rwkw which was its highest run but it was having fuel supply issues, it was retuned safely to 357rwkw where it sits now. The turbo and exhaust flow are basically on their limits.... to go higher i will need to do the clutch again, more fuel system upgrades and a bigger turbo, its so nice to drive now that any more would just spoil it.
Basics that got me to this level -
RB25 NEO stock internals
Garrett 3037 - 56T 0.82 rear
6Boost manifold, custom dump into 3"exhaust (Very quiet)
Tial 44mm MV-R with screamer or plumb back setup
Plazmaman Pro Series Thottle body/plenum/cooler & piping
Xspurt 1000cc injectors
HKS fuel rail - 6 fittings and 3/8 line i think
Bosch 044 pump, Sard Reg, Billet filter
Haltech PS2000 wire in with ethanol sensors and wide band (Full Flex tune by JEM)
HKS EVC 5
HKS Exhaust Cam gear and full Gates Racing timing belt kit
Tomei type B poncams, Performance valve springs and retainers
The list keeps going, but i just realised all this info is in my Signature :P Cost heaps to do but it an absolute dream to drive daily and is a laugh on boost!
Dyno run on E70 -
2000 r34 GTt
twin 40mm gates
6boost mani
044 in tank
running on 98
1990 R32 GTS-T
S1 RB25DET
6Boost + GT3582R + Turbosmart Progate 50mm
Greddy Intake
Power FC + Tomei Cams & Gears.
Sard 650 CC injectors and rail.
17.5 PSI
BP Ultimate 98
Tuned at Allstar Garage in Perth by Sean.
Hub Dyno
Edited by r32pat
Hey Guys,
Car made -
311rwkw on pump 98
HKS EVC 5
Dyno run on E70 -
Sorry it took so long to scan the dyno sheets.... I dunno how to embed them so here they are the lazy way -
Safe Tune High boost E85.pdfLow boost E85 vs Low boost 98.pdfGate Pressue E85 vs low boost 98.pdf
As you can see the high boost run comes on pretty aggressive :D
1999 R34 GTT
-110,000kms
-Stock trubo with heaps of end float
-Simota pod filter
-Full 3" stainless exhuast from the turbo back with x-force Hi-flow cat
-HDI boost controller
-Yellow jacket coils
170kw on 10.5psi dropping off to around 9psi rich as a dog
KW and Torque
KW and boost
Torque and boost
Edited by NZDRIFTER
S2 R33 skyline
550cc injectors
Front mount cooler
3.5inch turbo back exhaust
Hypergear SS1PU turbo
EBC
Split fire coil packs.
3inch custom intake with pod
Maximum power 261rwkws with 16psi of boost. Response king.
  • 3 weeks later...
before turbo upgrade
- blitz fmic return flow
- fgb manual boost controller 10psi
- 3inch exhaust catback back
- 98 fuel
198rwkws
after turbo upgrade
- Garrett gt30-76 turbo
- nistune
-profecb spec 2 boost controller
- cushion button clutch plate and pressure plate
- chromoly flywheel
- 3inch hi flow cat dump pipe and engine pipe ( full 3inch exhaust )
-740cc injectors
-355l/hr fuel pum
-z32 airflow meter
-blitz fmic return flow
-98 fuel
-custom pipe work to suit stock air box
281.9rwkws
Made 276 kw on 18psi tapering to 16psi, it did make 295 but timing was put back to make it safer
Mods are as follows
Z32
3" exhaust, no cat, 1 muffler (home-made)
600x400 bar and plate cooler with return flow piping, assuming its home-brand as i only paid $50.
Tial 44mm gate (17.64PSI) (no boost controller)
Hypergear SS2 0.82 type b
52mm Radiator
bcpr7es copper plugs
DW 740cc Injectors accompanied by a Bosch 044 (intank)
HKS pod 3 inch intake
Power FC on RB25 & 98 fuel
EVERYTHING else is standard
Edited by adam999111
R33 series 1 Gts-t
Apexi PowerFC
Z32 china copy :(
Unopened rb25det
Ex cam gear - set to 0 degrees
3inch turbo back decatted
FMIC
250l/h Walbro intank pump
Stock airbox with k&n panel filter for stealth mode.... ;)
Stock R34 turbo (OP6 rear)
243.0RWHP @ around 6500rpm
R33 GTST S2
Stock motor
FMIC
Spitfires
Nismo 740cc
Walbro fuel pump
Vipec ECU
GT3076 [Low mounted & Internally Gated]
3" Exhaust with Hi-Flow Cat
4" Intake pipe
Curretly making 302rwhp on 18psi
Car was having some troubles on dyno with poor fuel in the tank and the fuel not having enough timing in it. Car is going back on the rollers on tuesday for a retune and to fix any issues. Hoping to see just under 400 out of it
R33 GTST S2
Stock Motor
GTX3076 with external Tial44mm Gate 0.82rear
3 1/2 inch exhaust with 3inch rear oval muffler, 100cell cat
1000cc Xspurt injectors , walbro 400LPH E85 pump, turbosmart reg
Power FC, Z32 airflow
Apexi AVCR
Tomei 256 8.5mm cams
4inch intake pipe
Currently making 320kw on 16psi with a 20psi spike in midrange on Caltex flex fuel
Made 280kw on 16psi using 98
20psi at 4000rpm :-)
Edited by SliverS2
Finally got my 34 to dyno today, set up is a follows:
Standard NEO Engine
Apexi Power FC
Standard Injectors running 90%, standard AFM, BOV blocked off but am going to refit as having a few dramas with it idling when backing off from a rev
12pound on a Greddy Profec B
Walbro Intank with hard wiring mod done
HKS GT25/30 turbo - Standard manifold
Apexi Power Intake - This sounds insane when spooling
Cooling Pro turn flow FMIC
Full exhaust with Hi flow cat, 2 mid muffler and 2 on the outlet
BP 98 Fuel
228rwkw and 614Nm of torque
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
