Rb25 Turbo Upgrade, All Dyno Results
Nacho Vidal
93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
800cc injectors
600x300x75mm Front mounted cooler
Xforce 3inch turbo back exhaust
Profect B electric boost controller
Brea bolton manifold.
SS2 prototype (290612) Internally gated. 14psi actuator, internally gated.
4inch intake pipe
Adaptronic Plugin
Greedy EBC
Further evaluation on the SS2. it made 337rwkws on e85 externally gated it made 337rwkws at 18psi peek just touching 20psi. I've also trailed it based on internal gate running boost controller and straight off the actuator.
The solid red and green are from internal gate, Green is internal wastegate pressure:
Boost curve for all runs.
Also same car specifications, trailing SS3 prototype. made 387rwkws @ 24psi In fear of snapping con-roads it was done on a short 9 sec ramp, so the curve on paper does appear laggier then what it actually is.
R33 GTST S2
Stock motor
FMIC
Spitfires
Nismo 740cc
Walbro fuel pump
Vipec ECU
GT3076 [Low mounted & Internally Gated]
3" Exhaust with Hi-Flow Cat
4" Intake pipe
Curretly making 302rwhp on 18psi
Car was having some troubles on dyno with poor fuel in the tank and the fuel not having enough timing in it. Car is going back on the rollers on tuesday for a retune and to fix any issues. Hoping to see just under 400 out of it
Car has been tuned again, had a crank angle sensor fault aswell. car now makes 350hp. still a bit shot of what i wanted.
Edited by SCR48
Ok just had my rb25 neo from a r34 gtt tuned by efi in brisbane.
Mods std unopen rb25 neo
stage 1 pom tom cams
spitfire coil packs
550cc bosh injectors
hypergear hi-flow std op6 turbo .63 rear now.
head ported
std inlet manifold
std exhast manifold 3" exhaust from turbo back (by myself).
100 cel cat & straight through muf,
aeroflow 650hp fuel pump
running 98 ron
On 12psi max made 256.1 kw @ the rears wheels @6500rpm
Will get more but unable to set the timeing correctly as i don't have a lower timeing cover fitted as there wasn't one on the engine when i got it.
Once i get the cover will be able to wind up the boost to 16-18psi.'
Will upload dyno sheet on Monday or Tuesday.
R32 GTST
Stock RB25DET
Kando T67 10cm
Tial 44mm Wastegate
6Boost exhaust manifold
3" exhaust with single muffler
Random FMIC
Freddy Plenum
Bosch ID1000 injectors
Turbosmart FPR800
Walbro 400lph E85 compatible running E85
Splitfire Coilpacks
post-32498-0-35033400-1346680949_thumb.jpg post-32498-0-15284200-1346681004_thumb.jpg
R34 gtt
Stock RB25DET NEO
Power fc
Kando T67-25G
3" turbo-cat then 3.5" cat back
Spitfire coil packs
Deatschwerks 300lph pump (hardwired)
Siemens deka 60lb injectors
Z32 afm
Hybrid performance exhaust manifold
Blitz return flow FMIC
TurboSmart 50mm progate
Running 20psi on 98 octane.
Doesn't want to upload photo of dyno from le phone....
But it made 278.6rwkw @ 6750rpm and 462.5NM @ 5000rpm.
  • 4 weeks later...
R34 gtt
Unopened RB25DET NEO
Nistune
HyperGear ART43G2.5 Internal Gate
3" justjap dump-cat, 3"cat-exhaust
Deatschwerks 600cc Injectors
Walbro 341
Z32 afm
Stock Manifold
Cooling Pro Front Mount
252rwkw @ ~ 6000rpm 20psi
(338HP)
Boost drop is more than i would like, trying to work out what causing it.
Edited by jay-rod
310rwhp @ hubs, 1.3bar
Something not right with my setup, not making as much as it should.. I've since changed the restrictive Blitz Nur exhaust over with a straight through 3" system so hopefully could make a bit more.. yet to re-dyno
Stock RB25DET
HKS GT2540
HKS split dump pipe
3" front pipe
3" Catco high flow cat
3" Cat back
Apexi Power FC
Apexi pod filter
JDM S15 480cc injectors
Adjustable Fuel Press Reg.
Walbro GSS-342 fuel pump
FMIC
Latest results:
Red line is high boost setting at 18psi, blue line is low boost setting at 16psi with the gain set more conservatively to bring it on slower.
Mods:
Link G4 Plug-In
Greddy Profec B-Spec II EBC
Haltech 3 bar MAP sensor
Externally gated Hypergear ATR43 G3
Turbosmart Compgate40
1000cc Injector Dynamics injectors
Plazmaman FFP
Plazmaman 72mm throttle body
JJR 3" bellmouth dump/front pipe
VENOM 5" 100 cell cat
3" custom Kermit Engineering exhaust
Walbro GSS-342 in-tank fuel pump
GReddy FMIC
AGP triple core alloy radiator
stock GTR bov
custom Pro Fabrications alloy oil catch can/radiator overflow combo with Earls fittings
Splitfire coilpacks
HKS fuel rail
Performance Springs valve springs and retainers
Tomei Type-B Poncams
Headtorque custom bronze valve guides
ARP head studs.
R34 GTT
Unopened RB25DET
GT30/76r +lines
Greddy ProfecB II boost controller
Blitz 600x240x60 front mount
Nistune ECU
Denso highflow FP
Splitfire coilpacks
Z32 air flow
HKS BOV
Apexi pod
Custom 3" dump pipe
Custom 3" high flow cat
3" cat back
On 98 octane / 16PSI made 261RWKW
R34 Gt-t, 170,000k's old.
Unopened engine
Kando T67 anti-surge housing
Hybrid Performance Manifold
Tial 44mm MVR gate
Nistune ECU
Just Jap intercooler
750cc injectors
Z32 in the cooler piping
Splitfire's
K&N filter on 4" intake
3" Dump and straight through Exhaust with only a single hotdog
Walbro Pump
on 98 @ 17psi made 380rwhp, had lots of drama's with the Nistune, so hoping for some more after a retune once i have sorted all the issues, will put 20psi into it. Failing on dyno sheet atm.
800cc injectors
SS Ebay bolt on manifold
PU high flowed R33 turbocharger, Ceramic roller bearing, internally gated.
4inch intake pipe
Adaptronic Plugin
Greedy EBC
This is Billet SS2 in .82 Type B Ceramic roller bearing
Both runs are based on a ported stock exhaust manifold E85. Blue is with a .63 rear housing.
1999 Stagea RS4S
HKS 2835ProS
Nismo 480cc injectors
Plazmaman FMIC (turnflow)
3" Straight through exhaust with mid muffler and massive rear can (very quiet car)
260 deg type B Poncams
Greddy Profec B
Nistune (car has run with auto base image for around 2 years finally figured out that it was supplied incorrectly and just re-imaged)
Tidy up tune with Jez to check what if any WOT mapping changes were needed after installing the manual image. It is anyones guess what Nistune is doing under the surface. Plus I wanted to work more on getting the car off the line. The Stagea bogs down quite easily unless you give it the beans off the line. Changes made to very low load fueling and VCT has sorted out these issues.
  • Like 1
  • 3 weeks later...
Thought I'd have a look and add my info car is currently on the build again bigger turbo and intercooler
But here is some figures when finally complete and
On Dyno will post sheets of new power.
Currently 427kw revs taken to 8800.
Cracked r34 gtt 25det neo
Fully forged from ground up.
Valves seats rings arp head bolts, studs
Wiseco forgiez
Tomei poncams stage 2
Rc 720cc injectors Greddy intake
Hypertune 90mm throttle body
4 inch intake piping all round
SARd external gate
Custome sinco top mount mani
ARE surge pot fuel pump wallbro x 2
Nismo engine mounts to stop torque bend ( still engine pulls hard lol)
Hks t04s 1.0 exhaust wheel (nice change at 4000rpm no valve noise means no cops lol)
Apexi avcr
Apexi el2 gauges oil pressure,temp water And boost
Apexi rsm
3 1/4 inch exhaust with cat back
Arc cold air intake box
Spitfire coilpacks
Upgrade vct module It's awesome keeping vct trust me
Basicly it there's heaps of other things but that's basic core stuff.
427kw atw at 1.4 bar boost
On Bp 98 ultimate
Oh and vipec ecu
Nice to see heaps of other tough 25 and 20dets reppin.
Edited by Cyifly
  • Like 1
Car just came off the dyno today after a 18 month build up.
Nissan A31 Cefiro
RB25DET series one (unopened)
Garret GT3076R .82 rear
Deatsch werks 740cc injectors
Walbro fuel pump
Z32 AFM
Power FC
Greddy Plenum
HKS low mount manifold
3 inch turbo back exhaust
Tial 38mm gate
HKS Pod
Front mount
260.7kw @ 14psi
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
