R32 Sedan,
RB25 Neo, (drop in 260 pon cams, exhaust gear, arp studs, original head gasket)
Second hand Trust TD06 25G 10cm Turbo kit.
3" dump pipe, twin 2.5" "catback".
Plazmaman intake, GTR Cooler.
Vipec Plug and Play ECU for R34
Deatsch werks 1000cc injectors, (+ complete fuel system)
Fuel BP 98
436hp @ 1.15 bar (16.6psi) (I will push harder once i have ironed out any bugs with the new setup.) :)
Im away for work so will post up dyno sheet when I pick up the car, in a week or so (or when i remember)
1998 r34 gtt
unopened rb25 mostly stock apart from:
full 3" hks hi silent exhaust turbo back
Cooling pro intercooler
Greddy Profec b EBC
fuel pump
injectors 600cc
splitfire coilpacks
apexi pod filter
Garrett GT3076R internal gate bolt on std exhaust manifold
Link plug & play ECU
259Kw/atw
i think it works out to be 350hp/atw
Tuned my mark @ MRC
93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
800cc injectors
600x300x75mm Front mounted cooler
Brae High mount exhaust manifold
HPVA 50mm external gate
Xforce 3inch Cat back exhaust
100 Cell Cat
Profect B electric boost controller
ATR43SS2 .70 comp externall gated
4inch intake pipe
Adaptronic Plugin
The SS2 maxed out touch under 360rwkws (359.3rwkws) on 22psi of boost.
Boost:
its surprising of how much power and torque it picked up comparing to when its internally gated and fitted to a ported stock exhaust manifold.
Yellow / (pink due to no ink) is SS2 on high mount ext gate plumb back @ 22psi
Red is SS2 on ported stock manifold @ 22psi
Blue is SS2 on high mount ext gate plumb back @ 20psi
Also introducing Drift Havoc's R33 with unopened Rb25det engine running the same turbocharger similar setup and same fuel. Build up blog is linked below, Very good example for modifiers.
Ok finally tuned.
Big thanks to Andrew at Hyperdrive in Perth very good service.
RB25DET
Unopened
Touch over 15psi
HKS GT-RS Turbo
Apexi Power FC
JECS 750cc injectors
Walbro pump
Z32 AFM
FMIC
POD
3.5in turbo back
Decatted
Turbosmart dual stage BC,
Boost controller was causing dramas due to not being able to bleed enough air off and boost drops off slightly from 3500-4500 right in the midrange :( all because of a shit boost controller
Otherwise very happy with the result.
321.6rwhp @ 15psi
239rwkw
Edited by Badcredit33
1998 R34 GTT
Stock RB25DET NEO
3" metal intake
Z32 afm
Precision 5558 0.63a/r turbo- ported cover
Turbosmart Compgate 40mm off turbine housing
Cooling Pro FMIC
Stock exhaust + intake manifolds
3" dump with plumb back
100 cell metal cat
3" exhaust
Siemens Deka 60lb injectors
Walbro GS3442 fuel pump, direct voltage
Nistune
Yellow Jacket coils
286rwkw @18psi, intake temps getting hot, will change piping and crank boost up later, and post dyno sheet when I have access to a computer
rb25 neo unopened
ATS highflow OP6
std exhaust and intake mani's
3" exhaust with split dump
hks type s return flow cooler
z32
pod
scotty 3" metal intake
bosch 040 fuel pump
ID 725's
E85
270rwkw at 15psi. Room for more later but happy with the super-safe reliable power for now
Rb25det s1 unopen with cams
Hks gtrs
Hks cams 256in retaining vct 264ex with hks cam gear
Id725cc
Q45 throttle body
Link g4 extreme wire in
Boost control by link g4
Freddy manifold
3inch bell mouth dump pipe/ decat /3 1/4 cat back
Walbro intank fuel pump
Sard fuel reg
Mx7 vl turbo gearbox modified
276kw 18 psi 98oct tuned by mrc dyno tuning castal hill
Edited by D.s
98 R34 GTT
RB25DET
Hpi turbo to cat downpipe
Hks exhaust
Hks mushroom filter
R33 GTR Intercooler
Hpi turbo to cat exhaust downpipe
Apexi PowerFc
Bosch 044 fuel pump
Turbosmart boost tap
Stock turbo
206kw on 15psi
All done by the previous owner
Hopefully have my new turbo going in within the next few weeks, then after I get the plenum I'll get her retuned.
Cams and 1000cc injectors will be the final upgrade
Edited by RiseofBrutality
r33 1996 s2
stock motor
power fc
walbro intank pump
sard 550cc
plazmaman pro seris cooler
z32 in cooler piping
6boost mani
garrett 3037
pro gate 50mm
asr sump
os twin plate
3 1/2 zorst, no cat
306rwkw on 18 psi
tuned by INDEPENDENT MOTORSPORT
New update have now gone e85 every thing the same as above but have changed to walbro 400 intank and hi flowed standed 25 injectors makes 330rwkw
R33 S2 rb25det
-bosch 040
-JJR front dump pipe
-5" Venom highflow cat
-3" HKS superdragger catback, minus midmuffler
-JJR return flow front mount intercooler
-stock turbo
-stock ecu
BP 98 Ultimate
177.9rwkw powercruise dyno
Edited by MatthewT85
800cc injectors
Brae high mount exhaust manifold
HPVA 50mm external gate plumbed back.
100 Cell Cat
HyperGear re-engineered ATR-Billet SL220.5G
4inch intake pipe
Adaptronic Plugin
Max power is 346rwkws on E85 fuel. For Vs result compare to a Std SL220G please visit our building thread.
Same setup E85, using HyperGear re-engineered T67 or Billet ATR-SL225.5G
Maximum of 390rwkws with exhaust restriction, and stock cams is also maxing out.
93 S1 R33 GTS-T
Stock RB25 internally
Stock turbo
Stock ECU
No-name FMIC and SSQV
Pod filter
Boost tee running 14psi
Un-known aftermarket fuel pump
213kw Atw.
Can't help but feel I have some other parts but I can't see anything :blink:
'97 ECR-33 S2 115k
Unopened RB25DET + stock manifolds
Garrett GT3076R 52T 0.82A/R IW
Split dump, 3" exhaust, De-cat
Apexi filter, 4" intake, Z32 AFM
Blitz return flow FMIC
Tomei 555cc, DW301 pump
Apexi PFC
Splitfires
Greddy ProfecB-II
Very responsive 274rwkw @ 19psi (BP98) with linear power delivery
Edited by Checkbuzz
  • Like 1
800cc injectors
HPVA 50mm external gate atomsphrically ventilated.
100 Cell Cat
4inch intake pipe
Adaptronic Plugin
E85 fuel
Turbo: HyperGear ATR43SS1PU. Maxing out at 322rwkws power.jpg
Same setup as above using HyperGear Roller bearing ATR43SS-2 turbocharger, Maxing out at 374rwkws
For overall layout between the Std SL220G, ATR SL220.5G, SL25.5G, SS1PU, SS2BB, differences between Plumb back external gate V atmospheric ventilation and Bush V BB response differences. please visit our thread (click here).
Same spec as above ^^^^^
Results from Ball bearing G3 with updated comp profile:
E85 high mounted externally gated: Maxing out at 365rwkws
I've also done one more run with the The ATRSL25.5G. Little bit pissed as I'm missing 1KWs reaching 400rwkws. Maxed out at 399.1rwkws. Need bigger cams for the full potential of this turbo. Still, this is the highest power ever archived on stock cam from Trent's dyno library.
97 R33 GTS-t
Rebuild engine in 2005 with forged pistons and gtr rods.
HKS 2835Pro-s Turbo
HKS hi-power super silent exhaust.
Twin 2.5 inch to 3 inch front pipe.
3" front pipe
Trust R SPL intercooler
Trust adjustable exhaust cam gear
Z32 AIr Flow meter
Nismo Fuel Pump
Nismo 555cc injectors
Nismo fuel regulator
Apexi PFC + boost controller
Tuned at 17psi
1998 R34 GTT
Stock RB25DET NEO
3" metal intake
Z32 afm
Cooling Pro FMIC
100 cell metal cat
3" exhaust
Nistune
Yellow Jacket coils
Do you have any pics of the waste on the turbo?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
