Rb25 Turbo Upgrade, All Dyno Results
Nacho Vidal
ATR43SS4BB Alpha Prototype B turbocharger
93 model R33 GTST Forgied CP pistons, valve springs
Stock Cams
1200cc injectors
600x300x75mm Front mounted cool
Brae high mount exhaust manifold
HPVA 50mm external gate plumbed back.
Xforce 3inch Cat back exhaust
100 Cell Cat
Profect B electric boost controller
4inch intake pipe
Adaptronic Plugin
Power 435rwkws @ 25psi , E85 Fuel
  • 3 weeks later...
R33 gtst S2 Stock rb25det,
Gcg high flow turbo with turbo back exhaust,
after market low mount manifold,
Pod filter
Greedy style forward facing plenium
With 80mm throttle body
nismo 740cc injectors,
front mount
all controlled by a haltech platinum ecu with boost solenoid.
Running 20psi tuned by Ed at Autotech.
242.5kw at the wheels
Rb25det Neo OP6 high flowed factory turbocharger
Stock Cams
1200cc injectors
Stock exhaust manifold
HPVA 50mm external gate Teed from factory exhaust manifold
HPVA 18psi Internal gate actuator
100 Cell Cat
4inch intake pipe
Adaptronic Plugin
E85 Fuel
Max Power externally gated from stock exhaust manifold: 376rwkws @ 24psi
Max Power internally gated using stock exhaust manifold: 345rwkws @ 22psi
  • Like 1
96 R33 s2
150xxx k standard motor unopened
Garret 3082r . 82 rear
NZ hybrid performance manifold
Tial Mv-R 44mm wastegate
Plazmaman plenum + throttle body
1200cc injectors in stock rail with stock reg
Walbro 460 e85 pump
4" exhaust turbo back
PowerFC
Turbosmart bleed valve boost controller
344.8rwkw/462hp @23 psi on e85
Tuned by the one and only Guilt Toy aka Anthony Espinola. (Wont let me upload pic atm will try later)
1989 Silvia S13
Unknown KMS Rb25 had rings replaced few years ago thats it
KINUGAWA T25G Anti-Surge 4" - Comp. Whee: 60.2/78mm - Turbine Wheel: 54 / 61 mm
China high mount manifold
China front mount cooler
China unknown size wastegate LOL
China greddy copy plenum with non turbo Rb25 Throttle body
550cc Sards
Bosch 040 intank
3" Dump into twin 2.25" Side pipes under passanger door
PowerFC
98 BP fuel
351.5Rwhp / 260RWKW
  • 5 weeks later...
456RWRP/340RWKW 22PSI - Need better valve springs for more boost.
Standard RB25 NEO
Steam pipe high mount manifold
Garrett GTX3582R V-band housing
Turbosmart ProGate 50mm
Bosch 1000cc injectors
Proflow fuel rail
Tomei fuel pressure regulator
Plazmaman plenum
Haltech Platinum Pro ER34 Plug-in
Haltech 4 bar map sensor
Haltech boost control solenoid
Haltech flex fuel sensor
Splitfire coil packs
HKS HighPower exhaust
China 600x300x65mm FMIC
Walbro 460lph E85 fuel pump
Direct Clutch Services 10 puck button clutch
1535622_10202836245128500_640930943_n.jp
Edited by TheGeniusMoose
Stock RB25DET (head bolts, head gasket, internals)
hks 256/264 cams and ex cam gear
apexi pfc with a z32
garrett gt3076 .82 turbo with tial 44mm gate
GTR intercooler
Greddy plenum
Tomei 500hp lift pump with a 044 feed
Nismo fuel reg
23psi and BP Ultimate
BIG thanks to Trent and Cat from Chequered Tuning. Glad to see there are still legit people in the Auto industry.
GTR intercooler
Greddy plenum
Nismo fuel reg
R33 Rb25det Stock engine
Brae exhaust manifold
HyperGear SLSS2 Turbocharger
600x300x75mm Intercooler kit
3inches turbo back exhaust
1000CC injectors
Power FC
E85 Fuel
Final result of 356rwkws @ 20psi
  • Like 1
96 R33 s2
Walbro 460 e85 pump
PowerFC
R32 Sedan,
RB25NEO (unopened)
Full Race Manifold,
Twin MVR44 Gates
GTX4294R
Plazmaman Plenum
Plasmaman 100mm GTR intercooler
Custom 3" intercooler piping
Custom 4" exhaust
260 degree pon cams
Adjustable intake and exhaust gears (retained VCT)
Arp studs (changed one at a time with head still in place)
Factory valve springs, coilpacks headgasket etc.
Vipec Plug and play for R34
United E85
Allstar garage tune.
681hp @. ~25psipost-66887-13932700548444_thumb.jpgpost-66887-13932701579383_thumb.jpg
  • Like 1
R34 GTT RB25NEODet
usual suspects
FMIC
Blitz Boost controller
Cheapie Pod
stock turbo
stock injectors,intake
Big exhaust from turbo back , dont know size? should ask old owner
98octane BP fuel
Running 12psi the car made 201kw atw
cant find dyno sheet ? its somewhere
that was 2 years ago since that tune the blitz controller died and im now using a boost tee
got a few mods in mind, i was told to get a kando td06 20g as a bolt in kit but im looking around here thinking its too small
and a t67 would be a better choice, i wanna make max power! :yes:
few questions i got
so a t67 25g? 1000cc injectors, bosch 044 fuel pump , z32 afm and a nistune ecu and good tune should be about all i need for now yeah?
ive not found a kit for the 34gtt for the t67 soo, is it going to fit low mount or have to be changed to highmount?
be alot cheaper if i could get the t67 to fit low mount factory position yeah ?
if changed i gotta change the intercooler piping, exhaust manifold and intake ?
looking arond here and at 34geeteetee build thread is helping me out and what a machine!
will accumulate parts and then drop it in to the mech to get done then tuned
cheers and appoligies for the newb questions i just need to be told whats what ,
:woot:
  • 1 month later...
-Apexi Power FC
-1.2bar boost via blitz sbc
-PULP 98
-850cc injectors (remanufactured)
-GTR Fuel pump
-High flowed stock turbo (Steel t3 turbine, largest front wheel could fit)
-3" exhaust from down pipe back (3" coby resonator >3"RPS muffler)
229rwkw @ 16psi
sorry about the graph, but you get the idea.
Edited by Badgaz
  • 3 weeks later...
Rb25det
Factroy manifold with 38mm waistgate flange welded to it
proboost 38mm waistgate
GTX3071 .82 rear
greddy intake
nismo 555 injectors
camtech 268-9mm cams
link g4 plugin
20psi boost controled by link
grate result and pulls from low down to redline
315rwkw (420hp)
R33 rb25det
Unopened engine
550cc injectors.
21u high flow by hypergear
Greddy profec b type 2
Blitz return flow
Walbro gss342
Split fires
Power fc
98 octane
245kw @ 18psi potential exhaust restriction
    • Looks like a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
